Problem Parsing certain series
leandrodeassis
Post Wed Mar 09, 2016 11:44 pm
Hi, I'm having problem in Serviio to parse the metadata of the 11.22.63 miniserie.
Using for eg. 11.22.63 - S01E01.mkv doesn't work
anyone have clues to resolve that?
Serviio 1.9 on Raspberry Pi 2 (Oracle Java 1.8 on Arch Linux ARM)
Local Renderers: LG 42LB5800, LG 55UB8200, MX Player PRO.
Post Thu Mar 10, 2016 4:06 am
Re: Problem Parsing certain series
That series name will always have trouble being resolved by the normal method.
Try putting the IMBD reference for the series in the path name or in the filename (see http://wiki.serviio.org/doku.php?id=imb ... ata_naming) eg:
11.22.63 - S01E01 [tt2879552].mkv
or
....\path [tt2879552]\11.22.63 - S01E01.mkv
The second method (I think that works, I cant recall at the mo) has the advantage that it will apply to everything in the folder (ie. all other episodes).
leandrodeassis
Post Thu Mar 10, 2016 12:57 pm
DenyAll wrote:That series name will always have trouble being resolved by the normal method.
or
thanks, worked using the second method you propose :D
Users browsing this forum: Google [Bot] and 78 guests
