Upload license file issue
toniurbe
Post Thu Mar 10, 2016 7:44 pm
I bought yesterday your Serviio Pro license and I can't install it on a Mac computer. when I click on the Upload License file button, I get the windows to upload the license file, but when I'm browsing the files I have in my computer, all the files are disabled, I can't select the license file.
Do you know where is the problem?
Many thanks !!
Post Thu Mar 10, 2016 9:08 pm
Re: Upload license file issue
It's probably saved via Safari, which for whatever reason adds a .txt extension to the license file (so it ends up as xxxx.lic.txt). The .txt extension migh not be visible in the mas OS UI, mind you. You should see in in Terminal though.
You can either rename the file back to .lic, or downloaad the license file using Chorme / Firefox, or use Serviio 1.6 - it should enable you to add the .txt file.
toniurbe
Post Thu Mar 10, 2016 9:26 pm
I've downloaded the file from other browser and it works fine, many thanks.
