Cannot access console
anthonyd
Post Wed Mar 16, 2016 9:24 pm
I have serviio installed on a Fedora21 PC, serviio is up and runnning but when I browse to http://127.0.0.1:23424/console
I get the following error in my browser:
Not Found
The server has not found anything matching the request URI
You can get technical details here.
Please continue your visit at our home page.
I can browse to http://127.0.0.1:23424/mediabrowser and this will give me the login to the media browser but I cannot set a password as I cannot access the console.
I have checked firewalls etc and cant find anything.
The server is listening on the correct port:
[root@gateway opt]# netstat -tulpn | grep 23424
tcp 0 0 0.0.0.0:23424 0.0.0.0:* LISTEN 25514/java
Below is the serviio log:
2016-03-16 23:12:14,863 INFO [MediaServer] ------------------------------------------------------------------------
2016-03-16 23:12:14,864 INFO [MediaServer] Serviio DLNA media streaming server v 1.6 (rev. 9a1458ed77db)
2016-03-16 23:12:14,865 INFO [MediaServer] Petr Nejedly 2009-2015
2016-03-16 23:12:14,865 INFO [MediaServer] http://www.serviio.org
2016-03-16 23:12:14,865 INFO [MediaServer] Java 1.8.0_31-Oracle Corporation i386
2016-03-16 23:12:14,865 INFO [MediaServer] OS Linux 3.17.8-300.fc21.i686+PAE
2016-03-16 23:12:14,865 INFO [MediaServer] File encoding: UTF-8
2016-03-16 23:12:14,865 INFO [MediaServer] Headless mode enabled: true
2016-03-16 23:12:14,865 INFO [MediaServer] User: serviio
2016-03-16 23:12:14,865 INFO [MediaServer] User home dir: /opt/serviio
2016-03-16 23:12:14,866 INFO [MediaServer] Temp dir: /tmp
2016-03-16 23:12:14,866 INFO [MediaServer] ------------------------------------------------------------------------
2016-03-16 23:12:15,104 INFO [WebServer] Socket buffer set to 65535 bytes
2016-03-16 23:12:15,104 INFO [RestletServer] Starting Restlet server (/console) exposed on port 23423
2016-03-16 23:12:15,109 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2016-03-16 23:12:15,288 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2016-03-16 23:12:15,288 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2016-03-16 23:12:15,316 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2016-03-16 23:12:15,334 INFO [DatabaseManager] Using DERBY database language
2016-03-16 23:12:24,121 INFO [DBSchemaUpdateExecutor] Updating DB schema
2016-03-16 23:12:36,066 INFO [prefs] Created user preferences directory.
2016-03-16 23:12:45,438 INFO [DBSchemaUpdateExecutor] Dropping search index
2016-03-16 23:12:45,442 INFO [SearchManager] Starting up search engine
2016-03-16 23:12:46,551 INFO [DBSchemaUpdateExecutor] Cleaning temporary cache
2016-03-16 23:12:46,565 INFO [Device] Created UPnP Device with UUID: 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa, bound address: 192.168.0.1
2016-03-16 23:12:46,706 INFO [DBSchemaUpdateExecutor] Cleaning persistent cache
2016-03-16 23:12:46,738 WARN [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2016-03-16 23:12:47,060 INFO [MediaServer] ------------------------------------------------------------------------
2016-03-16 23:12:47,060 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2016-03-16 23:12:47,551 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2016-03-16 23:12:47,682 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2016-03-16 23:12:47,703 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2016-03-16 23:12:47,710 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2016-03-16 23:12:47,711 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2016-03-16 23:12:47,714 INFO [ProfilesDefinitionParser] Added profile 'Playstation 4' (id=ps4)
2016-03-16 23:12:47,717 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2016-03-16 23:12:47,720 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2016-03-16 23:12:47,725 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2016-03-16 23:12:47,728 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (J-series)' (id=sam_j)
2016-03-16 23:12:47,730 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2016-03-16 23:12:47,731 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2016-03-16 23:12:47,733 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2016-03-16 23:12:47,742 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2016-03-16 23:12:47,744 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2016-03-16 23:12:47,746 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2016-03-16 23:12:47,747 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2016-03-16 23:12:47,751 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2016-03-16 23:12:47,752 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2016-03-16 23:12:47,752 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2016-03-16 23:12:47,752 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2016-03-16 23:12:47,754 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2016-03-16 23:12:47,756 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2016-03-16 23:12:47,758 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2016-03-16 23:12:47,759 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2016-03-16 23:12:47,759 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2016-03-16 23:12:47,760 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2016-03-16 23:12:47,763 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2016-03-16 23:12:47,764 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2016-03-16 23:12:47,764 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2016-03-16 23:12:47,764 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2016-03-16 23:12:47,765 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2016-03-16 23:12:47,766 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2016-03-16 23:12:47,773 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2016-03-16 23:12:47,773 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2016-03-16 23:12:47,791 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2016-03-16 23:12:47,791 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2016-03-16 23:12:47,791 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2016-03-16 23:12:47,792 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2016-03-16 23:12:47,792 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2016-03-16 23:12:47,796 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2016-03-16 23:12:47,796 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2016-03-16 23:12:47,797 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2016-03-16 23:12:47,798 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2016-03-16 23:12:47,798 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2016-03-16 23:12:47,798 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2016-03-16 23:12:47,799 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2016-03-16 23:12:47,804 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2016-03-16 23:12:47,805 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2016-03-16 23:12:47,805 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2016-03-16 23:12:47,808 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2016-03-16 23:12:47,890 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2016-03-16 23:12:47,891 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2016-03-16 23:12:47,891 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2016-03-16 23:12:47,892 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2016-03-16 23:12:47,892 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2016-03-16 23:12:47,893 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2016-03-16 23:12:47,893 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2016-03-16 23:12:47,894 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2016-03-16 23:12:47,894 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2016-03-16 23:12:47,895 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2016-03-16 23:12:47,895 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2016-03-16 23:12:47,949 INFO [PluginCompilerThread] Looking for plugins at /opt/serviio/plugins
2016-03-16 23:12:47,955 INFO [PluginCompilerThread] Started looking for plugins
2016-03-16 23:12:47,966 INFO [UpdateChecker] Checking if a new version is available
2016-03-16 23:12:48,062 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg: /usr/lib/nvidia-304xx/libOpenCL.so.1: no version information available (required by ffmpeg)
2016-03-16 23:12:48,062 WARN [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
2016-03-16 23:12:48,067 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "dcraw": error=2, No such file or directory
java.io.IOException: Cannot run program "dcraw": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:136)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:187)
at java.lang.ProcessImpl.start(ProcessImpl.java:134)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 1 more
2016-03-16 23:12:48,121 WARN [MediaServer] DCRAW not found. Support for raw image files will be missing.
2016-03-16 23:12:48,149 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2016-03-16 23:12:48,198 INFO [Device] Updated bound IP address of Device with UUID: 0f47f1de-d79e-31c2-88ac-c2f7ac7b92aa, bound address: 192.168.0.1
2016-03-16 23:12:48,207 INFO [WebServer] WebServer starting on port 8895
2016-03-16 23:12:48,213 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2016-03-16 23:12:48,217 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface enp0s10 (enp0s10) and address 192.168.0.1, timeout = 0
2016-03-16 23:12:48,218 INFO [EventDispatcher] Starting EventDispatcher
2016-03-16 23:12:48,225 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2016-03-16 23:12:48,227 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2016-03-16 23:12:48,231 INFO [RendererSearchSender] Searching for Renderer devices
2016-03-16 23:12:48,704 INFO [RendererManager] Stored a new renderer: uuid='49f7bdb7-21fc-480e-8228-b678e2079548', name = 'MythTV AV Media Renderer', ipAddress='192.168.0.1', profile = '1', accessGroupId = '1'
2016-03-16 23:12:49,158 INFO [RendererManager] Stored a new renderer: uuid='526f6b75-536f-756e-6442-000d4b038b99', name = 'Roku SoundBridge M2000', ipAddress='192.168.0.7', profile = '1', accessGroupId = '1'
2016-03-16 23:13:14,285 INFO [FeedUpdaterWorker] Started looking for information about online resources
2016-03-16 23:13:14,429 INFO [FileDeltaWatcher] Using 'sun.nio.fs.LinuxWatchService' for delta scan
2016-03-16 23:13:14,463 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2016-03-16 23:13:14,476 INFO [LocalLibraryManager] Starting automatic library scan
2016-03-16 23:13:14,478 INFO [LibraryDeltaScanner] Starting the library delta scan
2016-03-16 23:13:14,481 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
Post Wed Mar 16, 2016 9:43 pm
Re: Cannot access console
Console is on port 23423.
Try http://127.0.0.1:23423/console
anthonyd
Post Thu Mar 17, 2016 5:05 am
Jees I'm an idiot :roll:
Was staring me in the face- serves me right for trying to debug stuff at midnight.
Thanks anyway
Users browsing this forum: Baidu [Spider] and 43 guests
