[Solved] Making serviio aware of proxy settings
Luckyfriend222
Post Wed Mar 30, 2016 5:20 pm
Hey Guys
I have just installed serviio 1.6 on Ubuntu 14.04 (it was not easy, ffmpeg etc), but in anycase. For some reason I cannot get serviio to update my files in such a way that it displays Series under the series folder, it only shows up under Folder > Series. I have tried renaming my files from
American Odyssey 101.mkv
American Odyssey S01E01 - Gone Elvis.mkv
and that didn't help. So I went further and tried to download a Series .nfo file (not episode .nfo) from thetvdb as prescribed by filebot, but still, nothing shows up.
So I reckoned the easiest way is for Serviio to fetch it online, but the problem is I am behind a corporate proxy. I added proxy settings to my java environment so that filebot can use it, and it does so successfully, but was wondering if there is a way to force serviio to use it as well? I do not see it added as a java property to be started with.
Any ideas will be much appreciated. If I have to use filebot, doesn't matter, but none of the tutorials or the forum posts on here has been any help.
Regards
Last edited by Luckyfriend222 on Thu Mar 31, 2016 8:04 pm, edited 1 time in total.
Post Wed Mar 30, 2016 8:10 pm
Re: Making serviio aware of proxy settings
You can add them as a system properties. http://serviio.org/index.php?option=com ... e&id=21#q3
Luckyfriend222
Post Thu Mar 31, 2016 9:04 am
Thanks zip
For any future reference to anyone, the settings to add to Java OPTS in serviio.sh is
-Dhttp.proxyHost=your.proxy.host
-Dhttp.proxyPort=port
Hope this helps someone else!
Users browsing this forum: No registered users and 58 guests
