subtitle problem
sam561
Post Tue May 10, 2016 8:24 pm
subtitle problem
hi,
i use serviio 1.6.1 with windows and my lg tv.
Some video with subtitle has sometime this text {pos/295} before text.
it is not the case with vlc player for example on my computer.
i made research and it is maybe the srt has TAG....
it there a solution with serviio to watch correctly subtitle without this symbol {pos.... ??
i am in utf8 and i try enable burn subtile in serviio without result...
thanks a lot
sam561
Post Wed May 11, 2016 7:47 pm
Re: subtitle problem
someone can help me ?
thanks a loy
sale89
Post Fri May 13, 2016 2:54 pm
no help bro, admin is epic retard i got the same problem and still nothing...Suggest you to delete this program
Image Image Image
Post Fri May 13, 2016 11:31 pm
@sale89: you've come to this forum looking for support for your copy of Serviio that uses a pirated key, and then complain about the lack of support you get from the person you have stolen from!!?? Suggest you take your own advice.
@sam561: as I understand it, the POS tag (and other tags in srt's) is supported by very few devices and (slightly more) software players. It would be up to your player to support these if playing subs natively.
While it may be possible for Serviio to deal with these when burning in subs, it would take development work, not something that can immediately be fixed (and would require you to burn in srt subs even if you're player supported them natively - which in itself is not an optimal solution). Have you looked at:
  • manually removing the tags. Edit the file with a text editor and remove the tags - obviously only practical if a small number of files affected. The subs will appear in the default position
  • if your LG supports ass files, convert your srt file to ass (which supports text positioning), using a converter available on the web. Not sure which, if any, support the POS tag and convert it, so you may have to test a few
Users browsing this forum: Google [Bot] and 62 guests
