Play all files from server
residend
Post Mon May 16, 2016 1:16 pm
How can i play all videos from server without folders structure? Or how to make folder ALL IMAGES (Or Videos)?
Post Mon May 16, 2016 10:45 pm
Re: Play all files from server
Not quite following your question. If you want a complete list of your videos without looking in different folders, don't look in the Folders view. Look in the Movies view. The Movies view provides everything you have in alphabetical order.
I don't use Serviio for Images, so can't speak to their presentation.
residend
Post Wed May 18, 2016 11:34 am
atc98092 wrote: If you want a complete list of your videos without looking in different folders, don't look in the Folders view. Look in the Movies view. The Movies view provides everything you have in alphabetical order.
"Movies" view only files wich metadata (online, local) , but all my files dosen't have any metadata, and i can't see this files in movies. (((
Post Wed May 18, 2016 12:17 pm
OK, got you there. I don't think there's anything in the existing version that provides what you're looking for. What is the reason there's no metadata for some videos? Are they non-commercial videos, such as home video?
You can turn metadata off for a folder, but I honestly don't know if that makes them visible in the Movies view. I would think so, but I've never tried it.
residend
Post Thu May 19, 2016 12:54 pm
atc98092 wrote:OK, got you there. I don't think there's anything in the existing version that provides what you're looking for. What is the reason there's no metadata for some videos? Are they non-commercial videos, such as home video?
Yes, it's small video clips, without any info, and file name looks like this: 12332423.avi , abbc12.avi etc..
