Cover Quality on Naim App
bongiaz
Post Mon Sep 19, 2016 9:04 pm
I Boys, I use your fantastic Serviio to share my music library from Mac to Naim Audio Streamer.
Its everything ok apart the images cover that was so little and with low quality in Naim App.
Someone can help me?
PS. I have the Serviio premium licence
Post Mon Sep 19, 2016 9:47 pm
Re: Cover Quality on Naim App
Try to replace this
      <ThumbnailsResolution>DLNA</ThumbnailsResolution>
with
      <ThumbnailsResolution>HD</ThumbnailsResolution>
in the generic profile (or whichever you're using)
bongiaz
Post Tue Sep 20, 2016 9:37 pm
Dear Zip,
thanks for hint, but nothing changes :cry:
I change the code in profile.xml , correct?
Post Tue Sep 20, 2016 10:18 pm
yes, and restart the server / PC
bongiaz
Post Thu Sep 22, 2016 9:44 pm
Yes I restart everything, but nothing change :|
I can try to reset all library and reset Serviio?
Post Thu Sep 22, 2016 10:55 pm
You can try to post detailed log of when using the app. You should get 2x resolution than before, 320x320.
Users browsing this forum: No registered users and 53 guests
