High CPU usage with no library content
Post Tue Oct 18, 2016 8:47 am
Re: High CPU usage with no library content
Thanks. I think it's the "RMI TCP Connection" threads causing it, but have no idea where they come from. It could be the http server library or the UPnP connections with your DLNA devices.
Google gives a lot of results for this, but I'm not sure which applies to your environment. You could try to play with your network settings / driver settings. Like disabling IPv6.
Also, I assume you don't have any online plugins in your installation..?
Dypsis
Post Fri Oct 21, 2016 8:35 am
And let us not forget ridiculously high memory usage in Serviio v1.7.1.1.
I'm going back to v1.6.1.
Post Fri Oct 21, 2016 2:34 pm
Dypsis wrote:And let us not forget ridiculously high memory usage in Serviio v1.7.1.1.
It might be due to the library being reindexing (if you went from 1.6.1 to 1.7.1.1)
Dypsis
Post Fri Oct 21, 2016 6:13 pm
ServiioService.exe is using 312 MB.
Is that acceptable to be running with that much all the time?
Version 1.6.1 used only a fraction of that.
Previous
Users browsing this forum: Baidu [Spider], Google [Bot] and 35 guests
