Serviio 1.8 Library Auto Update Doesn't Work
mmarauder
Post Sun Jan 01, 2017 11:54 pm
I'm on Serviio 1.8 Pro and my library auto update doesn't work. The force refresh works and will add all my new files and remove the old ones in a matter of minutes, but the auto update doesn't work at all. I have it checked, and I've tried restarting the app. It's running on Ubuntu. Any ideas. I switched my logging to DEBUG but so for I haven't seen anything to indicate why it's not working.
Post Mon Jan 02, 2017 12:56 am
Re: Serviio 1.8 Library Auto Update Doesn't Work
Look in your Library settings for the shared folder that isn't updating. Just above the OK button is a check box labeled "Use the poller mechanism for monitoring this folder". Enable that and see if it makes a difference.
mmarauder
Post Mon Jan 02, 2017 2:44 am
That fixed it thanks.
Jemsky
Post Mon Jan 02, 2017 4:26 pm
Hi
I've been having the same issue. I've reinstalled Serviio, enabled poller and a host of other suggestions but it just doesnt work. I have clicked force refresh and its just added a couple of files and wont add any more. Could someone kindly assist? I have a windows 10 machine and this recently stopped working
Post Mon Jan 02, 2017 9:29 pm
Turn on detailed logging, restart and then do a forced refresh. See what file its failing at.
