Pause problem on Yamaha R-N301
bakilb
Post Wed Jan 11, 2017 10:17 am
Hello!
On my Yamaha N301 network reciever the pause doesn't work. Next/Pre/Stop is perfect. I listen FLAC/MP3 files.
What is the problem?
thx
bakilb
Post Fri Jan 20, 2017 9:17 pm
Re: Pause problem on Yamaha R-N301
Any idea?
Post Fri Jan 20, 2017 10:14 pm
What profile are you using?
bakilb
Post Thu Jan 26, 2017 8:56 pm
Genreal DLNA profile.
Which one is the good for me?
Post Fri Jan 27, 2017 12:17 am
The generic profile sends everything as is, with no transcoding. If your player supports those formats (I'm not familiar with it) they should play no problem. I've heard of specific players having issues with trick play (FF and rewind) but not with the pause function. Just to try something, change to the DirecTV profile. This transcodes everything, and see if pause works. Not sure what it would tell us, but if pause doesn't work here either then it's likely something specific to the Yamaha player that can't be changed by Serviio. Sure seems like it should work, though.
bakilb
Post Thu Feb 02, 2017 10:33 pm
Thanks for your ansver.
Direct TV doesn't pause, Yamaha BD player also doesnt work, just like XBOX One. :(
None of them are good.
Microsoft W10 integrated server works with pause, but servioo is almost better....but I need the pause.
Post Fri Feb 03, 2017 1:05 am
That is strange. I can pause on all of my Roku boxes, my Sony BD player, and both of my smart TVs (Samsung and Panasonic).
bakilb
Post Sat Feb 04, 2017 12:31 pm
Thanks for your help. I will follow the further versions. I hope it will be fixed.
Users browsing this forum: Google [Bot] and 75 guests
