Issue with folders
Enclave01
Post Sat Feb 25, 2017 2:46 pm
Issue with folders
Hello.
I just installed serviio 1.8 on Windows 10 and everything works fine with my TV Samsung F6500 except Library.
I put into library folder with my downloads : M:\^^Downloads2 ( 2000 files 200 folders) , and serviio don't see movies ( except only one episode of tv show) , in the log I found a lot of information like this:
2017-02-25 14:55:42,178 DEBUG [MediaFileIndexer] Found file 'banshee.s02e03.720p.hdtv.x264-killers.mkv', checking if it's already in the Library
2017-02-25 14:55:42,178 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item M:\^^Downloads2\Banshee.S02.PACK.720p.HDTV.x264-PT\banshee.s02e03.720p.hdtv.x264-killers.mkv
2017-02-25 14:55:42,178 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: M:\^^Downloads2\Banshee.S02.PACK.720p.HDTV.x264-PT\banshee.s02e03.720p.hdtv.x264-killers.mkv, ignore case: true
2017-02-25 14:55:42,178 DEBUG [MediaItemDAOImpl] Media item M:\^^Downloads2\Banshee.S02.PACK.720p.HDTV.x264-PT\banshee.s02e03.720p.hdtv.x264-killers.mkv doesn't exist in DB yet
2017-02-25 14:55:42,179 DEBUG [MediaFileIndexer] File not in Library, will add it
2017-02-25 14:55:42,179 DEBUG [LibraryHelper] Checking if the file is complete using file lock
2017-02-25 14:55:42,179 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: M:\^^Downloads2\Banshee.S02.PACK.720p.HDTV.x264-PT\banshee.s02e03.720p.hdtv.x264-killers.mkv
2017-02-25 14:55:42,179 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: M:\^^Downloads2\Banshee.S02.PACK.720p.HDTV.x264-PT\banshee.s02e03.720p.hdtv.x264-killers.mkv
2017-02-25 14:55:42,179 DEBUG [ProcessExecutor] Starting C:\Programy\Serviio\bin\\..\lib\ffmpeg.exe -i M:\^^Downloads2\Banshee.S02.PACK.720p.HDTV.x264-PT\banshee.s02e03.720p.hdtv.x264-killers.mkv
2017-02-25 14:55:42,221 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (M:\^^Downloads2\Banshee.S02.PACK.720p.HDTV.x264-PT\banshee.s02e03.720p.hdtv.x264-killers.mkv). Message: Unknown video file type.
2017-02-25 14:55:42,221 DEBUG [PendingFilesCache] Adding file 'M:\^^Downloads2\Banshee.S02.PACK.720p.HDTV.x264-PT\banshee.s02e03.720p.hdtv.x264-killers.mkv' for the pending files cache
If I change localization for example from M:\^^Downloads2\Banshee.S02.PACK.720p.HDTV.x264-PT to M:\Banshee.S02.PACK.720p.HDTV.x264-PT and add it to library it work fine and there is no problem in log file.
Any idea?
Post Sun Feb 26, 2017 1:36 pm
Re: Issue with folders
I assume it could be the ^^ in the folder name
Enclave01
Post Sun Feb 26, 2017 4:18 pm
zip wrote:I assume it could be the ^^ in the folder name
Yeah, I check it first and no, that is not a problem. If I add to library another folder with "^^" in the name for example M:/^^^^Game of Thrones everything its ok. Maybe it is the problem with number of files and folders? Is in serviio any limits? And one more thing, in folder with problem there is a lot of files with different types ( music, movies, apps and more) - maybe that is the problem? Serviio need a folder with one of the type of files?
Post Mon Feb 27, 2017 5:07 pm
No, it can't parse the output of
Either the file is corrupted at that moment in time or I'm not sure.
Users browsing this forum: No registered users and 72 guests
