Naming TV Series folder and files
rumplestiltskin
Post Sat Jun 17, 2017 4:02 am
I can see all my folders and files if I go in through the "Folders" option. However, when I turn on the "Series" option, I see nothing in that folder (even after requesting a refresh). I'm thinking I may just have a bad naming system although everything worked fine with my TVMobili installation (also on a Mac).
As an example of what I'm using:
Media (shared folder)
TV Shows (folder inside of Media)
Grantchester (folder inside of TV Shows)
Grantchester.S02E01.mp4 (file name contained in the above folder)
No folders appear when I go into "Series" in the web browser so, of course, the file contained therein is also absent. Yet going in through the Folders choice shows all TV series folders and the files contained in each folder also appear.
Might someone point me to a fix? Thanks very much!
Barry
rumplestiltskin
Post Sat Jun 17, 2017 4:12 am
Re: Naming TV Series folder and files
My bad! I had a goofy setting in the Console apparently. Looks like in Presentation > Video the "Series" choice should have been "Display content only". I had it set to "Display Category". All the series are popping in as I go out of and back into Series.
Sorry for the fire drill!
Barry
