Encode RTSP directly to Servio
mlm
Post Fri Jul 14, 2017 11:07 am
We're using Livestream Studio for sending a stream to their platform, but can add a local RTSP destination as well. Can one send a RTSP stream directly (from whichever encoder) to Servio or do you have to have another "server"for the RTSP stream in-between to pull from?
Post Sun Jul 16, 2017 5:47 pm
Re: Encode RTSP directly to Servio
you can add rtsp live stream to Serviio. add it as an online source live stream.
mlm
Post Mon Jul 17, 2017 2:32 pm
zip wrote:you can add rtsp live stream to Serviio. add it as an online source live stream.
Thank you
What would one then use as the URL, the encoder?
Post Wed Jul 19, 2017 1:49 pm
I assume so. Whatever is broadcasting the rtsp stream.
