InvalidMediaFormatException
manudar
Post Thu Aug 03, 2017 3:26 pm
Hi, I use serviio to transcode the TV channes from a VBOX DTV with a plugin that I did.
It worked very well for all the channel on V 1.8 and 1.7.1 but with 1.9, there is one channel (out of 34) that gives an error.
WARN [FeedUpdaterWorker] Failed to retrieve online item information for http://192.168.5.100:55555/PARAMOUNT%20CHANNEL. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:321)
at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveTechnicalMetadata(FeedUpdaterWorker.java:246)
at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:120)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:481)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:100)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:138)
at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:300)
I executed ffmpeg -i "http://192.168.5.100:55555/PARAMOUNT%20CHANNEL" and this is the output:
ffmpeg version 2.7.1 Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.9.3 (crosstool-NG 1.20.0) 20150311 (prerelease)
configuration: --prefix=/usr --incdir='${prefix}/include/ffmpeg' --arch=i686 --target-os=linux --cross-prefix=/usr/local/x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu- --enable-cross-compile --enable-optimizations --enable-pic --enable-gpl --enable-shared --disable-static --enable-version3 --enable-nonfree --enable-libfaac --enable-encoders --enable-pthreads --disable-bzlib --disable-protocol=rtp --disable-muxer=image2 --disable-muxer=image2pipe --disable-swscale-alpha --disable-ffserver --disable-ffplay --disable-devices --disable-bzlib --disable-altivec --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libmp3lame --disable-vaapi --disable-decoder=amrnb --disable-encoder=zmbv --disable-encoder=dca --disable-encoder=ac3 --disable-encoder=ac3_fixed --disable-encoder=eac3 --disable-decoder=dca --disable-decoder=eac3 --disable-decoder=truehd --cc=/usr/local/x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu-ccache-gcc --enable-yasm --enable-libx264 --enable-encoder=libx264
libavutil 54. 27.100 / 54. 27.100
libavcodec 56. 41.100 / 56. 41.100
libavformat 56. 36.100 / 56. 36.100
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 16.101 / 5. 16.101
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 2.100 / 1. 2.100
libpostproc 53. 3.100 / 53. 3.100
[http @ 0x1375700] HTTP error 500 Internal Error
http://192.168.5.100:55555/PARAMOUNT%20CHANNEL: Server returned 5XX Server Error reply
Any idea of why this is happening with version 1.9 and not with previous ones? I use it on a Synology nas (broadwell architecture)
Post Sun Aug 06, 2017 2:31 pm
Re: InvalidMediaFormatException
There is new ffmpeg with 1.9 maybe it sends something the server doesn't like and returns 500 error. Or it can just be temporary error on their side. Does the url work in VLC?
