Subtitle unreadable in MedisBrowser while readable on TV
iwrite
Post Sun Aug 06, 2017 4:16 pm
I have Serviio v1.9 installed on Windows 10 Pro. Currently the issue is that non-English subtitles in Unicode or UTF-8 srt file can be displayed on my Samsung H-Series TV perfectly, but it is not readable characters displayed in MediaBrowser. If I save the subtitle srt file as ANSI format, it's readable in MediaBrowser but turns to unreadable characters on my TV.
I was wondering if there is any way to make the non-English subtitle works in both Samsung H TV and MediaBrowser?
BTW not sure if it matters, I have to disable Transcoding as it doesn't work correctly on my Samsung H-Series TV (no subtitle, wrong length time, sometimes failed loading, etc.)
Post Mon Aug 07, 2017 6:16 pm
Re: Subtitle unreadable in MedisBrowser while readable on TV
Can you create a ticket on bitbucket and attach the subtitle file there? The one that doesn't work in MediaBrowser. Also do you have any encoding settings on the subtitles tab in console?
Users browsing this forum: Google [Bot] and 39 guests
