Audio "Artist" artwork metadata issue
Paul C
Post Fri Sep 29, 2017 2:07 pm
The "Artists" art work is sometimes wrong due to inclusion of composer data rather than only using the artist/album data.
I have tried it on several control units (BubbleUPnP, Mezzmo and Asset Control) with the same problem so it points to a Serviio issue.
An example is the artist artwork for Al Green showing an album cover by Seal (as there are two tracks "composed" by Al Green on the Seal album).
(raised Issue #1029.)
Post Tue Oct 03, 2017 3:21 pm
Re: Audio "Artist" artwork metadata issue
where do you get the artwork from? Is that in MediaBrowser?
Paul C
Post Tue Oct 03, 2017 5:10 pm
The .jpg was taken from the BubbleUPnP control app. Mezzmo and Asset Control control apps show the same as I indicated.
I have now looked at "Artists" level category artwork on MediaBrowser as well which is exactly the same for Al Green (i.e. Seal album).
I have also proved that by temporarily changing the composer I can correct the issue. Ray Charles album artwork was appearing for several different artists e.g. "I Got a Woman" and "What'd I Say" composed by Charles have been recorded by many artists.
I have also checked on "Album Artists" category artwork on MediaBrowser and there is the same issue - JJ Cale is showing Eric Clapton artwork and Jeff Beck is showing Joe Bonamassa artwork - because of composer issues.
Post Tue Oct 03, 2017 8:33 pm
Thanks, should be fixed in 1.9.1
Paul C
Post Thu Oct 05, 2017 1:33 pm
Thanks for that.
Also for the option to switch off "All Music" feature you previously implemented at my request.
Paul C
Post Mon Feb 19, 2018 2:26 pm
zip wrote:Thanks, should be fixed in 1.9.1
zip Thanks for fixing this issue.
Artwork all looks correct now in 1.9.1.
