1.9.1. Update takes a huge toll on CPU
jpires
Post Sun Feb 25, 2018 8:13 am
Hi
I have just noticed after updating to version 1.9.1 that its service is using almost 80% of the computer CPU.
I did not have this issue with the previous version.
Regards,
Jose
Post Sun Feb 25, 2018 4:37 pm
Re: 1.9.1. Update takes a huge toll on CPU
Depending on the version of Serviio you updated from, Serviio might be doing something to upgrade your database. Depending on the number of items in your DB, this could take some time.
jpires
Post Mon Feb 26, 2018 8:05 am
Hi
Thanks for your comment
I have updated from 1.9 and it's the same database I had before, so I am quite puzzled.
As soon as I stop Serviio service I regain 79% to 80% of CPU usage.
I would like to revert to 1.9 but I do not where to find it.
Regards
Jose
Post Tue Feb 27, 2018 1:26 pm
You should be able to download prior versions by changing the download link to the desired version, so http://download.serviio.org/releases/se ... -setup.exe becomes http://download.serviio.org/releases/se ... -setup.exe
Users browsing this forum: No registered users and 50 guests
