Unable to retrieve metadata from TMDB
ccaptain00
Post Sun Feb 25, 2018 5:22 am
I have 2 files that I can't get added to the library. They are named exactly as they are on www.themoviedb.org.
I have added the year and the IMDb ID in the filename with no luck.
The files are:
11-11-11 - (2011) (tt1712159).MP4
Lt. Robin Crusoe U.S.N. (1966) (tt0060640).MP4
Thanks for any assistance. Still waiting for that embedded metadata extractor ;)
Post Sun Feb 25, 2018 4:42 pm
Re: Unable to retrieve metadata from TMDB
When you are using the IMDB tag, I don't believe the year is necessary. That might be confusing the algorithm. http://wiki.serviio.org/doku.php?id=imb ... ata_naming
ccaptain00
Post Tue Feb 27, 2018 8:05 pm
I got Lt. Robin Crusoe U.S.N. to add ,but not the movie 11-11-11.
I tried 11-11-11 (tt1712159) as my file name as well.
Does anyone know if Serviio uses TMDB's alternative tiles also? I don't believe so as I tried those as well. Though it might help in this situation.
Post Wed Feb 28, 2018 12:35 pm
Since you're using the tt number, I wouldn't think the name is as important. I checked both themoviedb and imdb, and they both agree with the title name as you have. I'm out of town right now, but when I return home I'll make a dummy file and use my file naming program to see if it identifies it differently, or offers any alternate name. then I'll see if my Serviio recognizes it.
ccaptain00
Post Wed Feb 28, 2018 7:53 pm
atc98092 wrote:Since you're using the tt number, I wouldn't think the name is as important. I checked both themoviedb and imdb, and they both agree with the title name as you have. I'm out of town right now, but when I return home I'll make a dummy file and use my file naming program to see if it identifies it differently, or offers any alternate name. then I'll see if my Serviio recognizes it.
Thank you.
Post Thu Mar 01, 2018 12:21 pm
If you remove the dashes you should be fine - "111111 [tt1712159].mkv" worked for me.
ccaptain00
Post Thu Mar 01, 2018 10:43 pm
DenyAll wrote:If you remove the dashes you should be fine - "111111 [tt1712159].mkv" worked for me.
That worked. Thank you.
