[Solved] Problem x509
BlackGeare
Post Tue Mar 06, 2018 4:20 pm
Hello everyone, I apologize for my English, but I am an Italian user.
I would like to use the serviio on Linux Mint 18.3 x64, but the server will not boot and the console will report an ERR_CONNECTION_REFUSED error from the localhost on 23423 port ...
My Java version:
$ java -version
java version "1.8.0_151"
Java(TM) SE Runtime Environment (build 8.0.5.5 - pxa6480sr5fp5-20171114_01(SR5 FP5))
IBM J9 VM (build 2.9, JRE 1.8.0 Linux amd64-64 Compressed References 20171102_369060 (JIT enabled, AOT enabled)
OpenJ9 - 7ade437
OMR - 1b656cb
IBM - 59c3d96)
JCL - 20171113_01 based on Oracle jdk8u151-b12
and the log file:
2018-03-06 16:54:22,240 INFO [MediaServer] ------------------------------------------------------------------------
2018-03-06 16:54:22,240 INFO [MediaServer] Serviio DLNA media streaming server v 1.9.1 (rev. 5ccd9739d6ec)
2018-03-06 16:54:22,240 INFO [MediaServer] Petr Nejedly 2009-2017
2018-03-06 16:54:22,240 INFO [MediaServer] http://www.serviio.org
2018-03-06 16:54:22,240 INFO [MediaServer] Java 1.8.0_151-IBM Corporation amd64
2018-03-06 16:54:22,240 INFO [MediaServer] OS Linux 4.13.0-36-generic
2018-03-06 16:54:22,240 INFO [MediaServer] File encoding: UTF-8
2018-03-06 16:54:22,257 INFO [MediaServer] Headless mode enabled: true
2018-03-06 16:54:22,257 INFO [MediaServer] User: blackgeare
2018-03-06 16:54:22,257 INFO [MediaServer] User home dir: /home/blackgeare
2018-03-06 16:54:22,257 INFO [MediaServer] Temp dir: /tmp
2018-03-06 16:54:22,257 INFO [MediaServer] ------------------------------------------------------------------------
2018-03-06 16:54:22,271 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2018-03-06 16:54:22,283 INFO [DatabaseManager] Using DERBY database language
2018-03-06 16:54:23,456 INFO [DBSchemaUpdateExecutor] Updating DB schema
2018-03-06 16:54:27,153 INFO [DBSchemaUpdateExecutor] Dropping search index
2018-03-06 16:54:27,156 INFO [SearchManager] Starting up search engine
2018-03-06 16:54:27,248 INFO [DBSchemaUpdateExecutor] Cleaning temporary cache
2018-03-06 16:54:27,257 INFO [WebServer] Socket buffer set to 65535 bytes
2018-03-06 16:54:27,257 INFO [Device] Created UPnP Device with UUID: 9910f445-e26c-335b-99a8-8ff8acd7afc8, bound address: 192.168.1.62
2018-03-06 16:54:27,297 INFO [DBSchemaUpdateExecutor] Cleaning persistent cache
2018-03-06 16:54:27,304 WARN [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2018-03-06 16:54:27,348 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2018-03-06 16:54:27,349 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2018-03-06 16:54:27,350 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2018-03-06 16:54:27,350 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2018-03-06 16:54:27,376 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: java.security.NoSuchAlgorithmException: SunX509 KeyManagerFactory not available
java.lang.RuntimeException: java.security.NoSuchAlgorithmException: SunX509 KeyManagerFactory not available
at org.serviio.restlet.RestletServer.runServer(RestletServer.java:93)
at org.serviio.MediaServer.main(MediaServer.java:128)
Caused by: java.security.NoSuchAlgorithmException: SunX509 KeyManagerFactory not available
at sun.security.jca.GetInstance.getInstance(GetInstance.java:171)
at javax.net.ssl.KeyManagerFactory.getInstance(KeyManagerFactory.java:12)
at org.restlet.engine.ssl.DefaultSslContextFactory.createSslContext(DefaultSslContextFactory.java:331)
at org.restlet.ext.simple.HttpsServerHelper.start(HttpsServerHelper.java:98)
at org.restlet.Server.start(Server.java:588)
at org.restlet.Component.startServers(Component.java:637)
at org.restlet.Component.start(Component.java:562)
at org.serviio.restlet.RestletServer.startComponent(RestletServer.java:172)
at org.serviio.restlet.RestletServer.runServer(RestletServer.java:80)
... 1 more
2018-03-06 16:54:27,377 WARN [IndexedDiskCache] Region [subtitles] Disk cache not shutdown properly, shutting down now.
2018-03-06 16:54:27,377 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2018-03-06 16:54:27,377 WARN [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2018-03-06 16:54:27,377 WARN [IndexedDiskCache] Region [subtitles_metadata] Disk cache not shutdown properly, shutting down now.
2018-03-06 16:54:27,377 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
Unfortunately I'm not very practical, how can I solve the problem? Thank's a lot
Post Tue Mar 06, 2018 4:37 pm
Re: Problem x509
Did you install Java before installing Serviio? With Linux, you must install Java separately, as it is not included with Serviio.
BlackGeare
Post Tue Mar 06, 2018 9:47 pm
Re: Problem x509
Sure. I installed version java version "1.8.0_151". I specified the version in my previous post.
Post Tue Mar 06, 2018 10:42 pm
Re: Problem x509
BlackGeare wrote:Sure. I installed version java version "1.8.0_151". I specified the version in my previous post.
Whoops: apologies, I missed that :oops:
Beyond that, I installed Serviio on a Linux Mint computer just last week without issue. I'll check what version of Java I installed, just to see if it differs from yours.
BlackGeare
Post Tue Mar 06, 2018 10:54 pm
Re: Problem x509
Thank you very much for your availability.
jk50
Post Tue Mar 06, 2018 11:24 pm
Re: Problem x509
I think your problem is caused by using IBM java .If you don't need IBM java for something else, try uninstalling IBM java, and installing either
openjdk java or oracle java.
Post Wed Mar 07, 2018 2:53 am
Re: Problem x509
Your Java version may certainly be the issue. The Serviio log says I'm running "Java 1.8.0_151-Oracle Corporation amd64". That's a little strange, since this computer is running an Intel i3-2120 CPU. But running java from the command line says
 $ java -version
openjdk version "1.8.0_151"
OpenJDK Runtime Environment (build 1.8.0_151-8u151-b12-0ubuntu0.16.04.2-b12)
OpenJDK 64-Bit Server VM (build 25.151-b12, mixed mode)
I can't remember how I retrieved Java, but I think it was via apt-get, and not the Software Manager tool. Then again, maybe not. I'm looking at Software Manager right now, and it shows that I have "default-jre" installed, with this version saying "2:1.8.56ubuntu2". Software Manager reports dozens of different types of Java items available, but I think the "default-jre" is the standard runtime you should use.
I trust what the command line version is reporting as displaying the most accurate version number being used by the system.
BlackGeare
Post Wed Mar 07, 2018 8:50 am
Re: Problem x509
These are all the Java packages installed on my PC:
Post Wed Mar 07, 2018 8:54 am
Re: Problem x509
you should be able to get OpenJDK Java, rather than the IBM one.
BlackGeare
Post Wed Mar 07, 2018 9:36 am
Re: Problem x509
zip wrote:you should be able to get OpenJDK Java, rather than the IBM one.
I tried only with the Openjdk-9-jre in a virtual machine with the same system but nothing :-(
jk50
Post Wed Mar 07, 2018 10:18 am
Re: Problem x509
Looking at your earlier attachment ,you have both IBM java and Openjdk 8 java installed. Your system was defaulting to IBM java.
I don't know what you your trying in the virtual machine ,but you don't want Openjdk-9-jre you need Openjdk-8-jre .
Let's see if we can get you sorted out. Open a console and run,
java -version
and tell us the result. Run this command
sudo update-alternatives --display java
BlackGeare
Post Wed Mar 07, 2018 11:37 am
Re: Problem x509
Thank you so much .. I have created a virtual machine with linux mint virgin for testing purposes, I have only installed OpenJava, FFmpeg and the requirements to perform the serviio, but it does not work anyway.
By launching the commands, in the real machine, I get:
$ java -version
OpenJ9 - 7ade437
OMR - 1b656cb
IBM - 59c3d96)
For the second command:
$ sudo update-alternatives --display java
[sudo] password di blackgeare:
java - modalità manuale
link best version is /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java
il collegamento attualmente punta a /usr/lib/jvm/java-ibm-x86_64-80/jre/bin/java
link java is /usr/bin/java
slave java.1.gz is /usr/share/man/man1/java.1.gz
/usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java - priorità 1081
slave java.1.gz: /usr/lib/jvm/java-8-openjdk-amd64/jre/man/man1/java.1.gz
/usr/lib/jvm/java-ibm-x86_64-80/jre/bin/java - priorità 80
jk50
Post Wed Mar 07, 2018 12:21 pm
Re: Problem x509
Run this command,
sudo update-alternatives --config java
you should be presented a list of installed java run times, choose the selection that includes this line
that should make your system use openjdk.
You can check by running
java -version
It should return something similar to this
BlackGeare
Post Wed Mar 07, 2018 1:28 pm
Re: Problem x509
Wow it's great ... It finally works! I selected the path that you indicated to me (the one with the automatic mode), I ran serviio.sh and the console and it works.
Thank you so much for the help you gave me
now the java version displays:
$ java -version
