Episodes for "9-1-1" w/IMDB ID show up as "9 end 2 outs"
phillyjeep
Post Thu Jan 18, 2018 4:56 pm
I noticed the episodes of the new tv series "9-1-1" were showing up in Serviio as "9 end 2 outs".
Following the instructions at http://wiki.serviio.org/doku.php?id=imb ... ata_naming I added the imdb id to each episode as follows:
9-1-1 - S01E01 - Pilot [tt7415864].mkv
9-1-1 - S01E02 - Let Go [tt7657550].mkv
9-1-1 - S01E03 - Next of Kin [tt7611364].mkv
The directory they are in is named "9-1-1"
I verified the IMDBids Ids for each episode are correct on TheTVDB and TheMovieDB websites.
The ones I renamed and a new episode I added this morning still show as "9 end 2 outs".
Under "Descriptive metadata" "online metadata sources" is selected.
I also tried "Force refresh", "Rescan video metadata".
The episodes were still appearing as "9 end 2 outs".
Finally I tried renaming the files without the dashes in the title of the series, like "911 - S01E01 - Pilot [tt7415864].mkv" and serviio found the series (and irinically Serviio displays it with the dashes).
So my questions are:
- Why did it not work with the IMDB ID?
- Why did it work when I removed the dashes in the series name? I recall I used to have the name issue with the X-Files for a long time and had to remove the dash in that title as well, but don't anymore.
Thanks...
Clients: LG UF8500 4K 3D LED TV, Roku 4K TV, Roku 4, Roku 4k Ultra, WD-TV Live Streaming (2nd gen), WD-Live Play (3rd gen), Toshiba Blu-Ray BDX5300KU, Android Tablet(s), iPhone 6s, Amazon Fire
Media Server: Serviio 1.9, AMD FX-9590 8-Core 4.8Ghz, G.Skill 32GB 2400 MHz DDR3, Windows 10 Pro 64, 500GB Samsung SSD (System) and 250GB Samsung SSD (transcoding), & 40TB for media & data storage.
Dragonheart
Post Tue Mar 27, 2018 11:08 pm
Re: Episodes for "9-1-1" w/IMDB ID show up as "9 end 2 outs"
You have to use IMDB id of the series, not of particular episode.
Use tt7235466.
In my case it did the trick.
