Is it possible to downgrade?
goffyxue
Post Tue Apr 24, 2018 5:41 pm
Is it possible to downgrade to older versions (1.9)?
Post Tue Apr 24, 2018 8:17 pm
Re: Is it possible to downgrade?
I would think that that installing 1.9 over 1.9.1 might not cause a problem, but I always recommend doing a clean install if you are going to downgrade. That way you don't risk some minor change that actually impacts functionality.
What is the reason you desire a downgrade? Perhaps we can help with any issue you're having.
goffyxue
Post Tue Apr 24, 2018 8:22 pm
Thanks for your response.
Where can I download the 1.9 or other older version installation files? I can't find it anywhere on this site.
Post Wed Apr 25, 2018 1:03 pm
To download previous versions, copy the URL for the current download and edit the version number. For example, the current download URL for the Windows version is
http://download.serviio.org/releases/serviio-1.9.1-win-setup.exe
Edit the URL and change 1.9.1 to 1.9, or whatever version you desire. If you want the install for a different OS, copy the URL from the download page and edit it the same way.
bolzass
Post Wed Apr 25, 2018 2:11 pm
Hi goffyxue, as atc98092 says just change version and/or platform. For instance, 1.9 for linux:
[url]http://download.serviio.org/releases/serviio-1.9-linux.tar.gz[/url]
For the specific case of downgrading from 1.9.1 to 1.9, there is no special matter to take into account (I did it) -not as to go to 1.8 o 1.7 as it changes the DB-; but anyway, make always a backup before doing it!
Regards,
L.
goffyxue
Post Wed Apr 25, 2018 5:33 pm
Thank you all for your kind help! Successfully reverted back to 1.9.
