Serviio supports BDMV folder ?
gonwg
Post Thu Dec 17, 2015 3:57 pm
I have a bunch of Blu Ray movie files saved using BDMV folder structure (BDMV\).
My player is OPPO BDP-105.
When I copied the BDMV folder into a USB, and plugged it into OPPO, the player plays the movie right away.
Now I installed Serviio on my desktop pc which contains the BDMV folders.
And my OPPO is connected with Serviio.
Is it possible that the OPPO can play the blu ray movies directly using Serviio, instead of using USB ?
Any advise ?
Thanks ahead.
larryhiles
Post Wed May 23, 2018 2:02 am
Re: Serviio supports BDMV folder ?
I know that VLC supports BDMV folder, but not sure whether Serviio is a BDMV player or not, try VLC?
Post Wed May 23, 2018 1:43 pm
NO, it's not supported (at least not for stacking it into 1 file)
