"Keep Library Automatically Updated" Not Working
Erikson
Post Sat Jul 28, 2018 8:39 pm
Hey guys, Serviio works almost flawlessly for me.
Except I need to "force refresh" my library from the Serviio admin web page for newly added shows to show up in my library.
I have a folder with all my media as follows
D:\Shows\
When new shows are finished downloading from SABnzbd, they get moved into
D:\Shows\ShowName\Episode.mkv
At this point I need to go into Serviio admin web page and do a "Force refresh" for the Episode.mkv to show up.
I also have the "Keep Library Automatically Updated" checked.
Any help?
Windows 10 Pro
Latest Serviio
Post Sat Jul 28, 2018 9:01 pm
Re: "Keep Library Automatically Updated" Not Working
You can try changing to the Poller method. Go to the Library tab in the Serviio console, open your folder location for editing, and check the box labeled "Use the poller mechanism for monitoring this folder".
Erikson
Post Sat Jul 28, 2018 9:12 pm
atc98092 wrote:You can try changing to the Poller method. Go to the Library tab in the Serviio console, open your folder location for editing, and check the box labeled "Use the poller mechanism for monitoring this folder".
Oh good idea. I'll try that, thanks! I'll report back in a few days.
