HOWTO: Make Serviio auto-start under Linux (Red Hat, Fedora,
a50mhzham
Post Thu Aug 23, 2018 1:52 am
For new Linuces, the old System V / init.rc approach is no longer used. Linux flavors derived from Red Hat (Fedora, CentOS, others) now use SystemD, and its control / inspection utility, systemctl.
Let's say you don't want to do a deep dive into systemd and systemctl, you just want to provide a more systematic way of starting / stopping Serviio, and make sure it starts on boot without any intervention. Oh, and it shouldn't start up until the machine's network is up & running. You don't want to have to learn overmuch about systemd units, targets, wants, and all the other systemd terminology.
I'm your guy.
First, these instructions were developed on a Fedora 28 machine, in August 2018. If you're not using a Red Hat derived system, odds are this won't work for you. To see if it will, look for the first clue. Become root (use su -) and run the commands below
su -
systemctl
as root. If you get a huge list of devices, services, targets, and stuff, then you're on the right track.
Then go to the /etc/systemd/system directory and see what's in there:
cd /etc/systemd/system
ls -l
You should see some "services" and some "wants" and some other stuff. Specifically, you're looking for multi-user.target.wants a directory that represents stuff that should be started up as a result of the system reaching the multi-user run-state, meaning that networking and other multi-user support has started up. Don't tinker (directly) with anything in multi-user.target.wants
Below, you use an editor to create and update a system config file. That means vi, vim, emacs, elm, pine, nano, gedit, or similar. If you use a word processor and mangle the file, don't even ask- it's not going to work. I think kwrite works too.
Next, fire up your favorite editor (real men use vi right?) and create /etc/systemd/system/serviio.service and type the parameters shown into it:
vi /etc/systemd/system/serviio.service
and the contents should be:
[Unit]
Description = Serviio DLNA media streaming server
After = network.target
[Service]
ExecStart = /usr/local/bin/serviio/bin/serviio.sh
[Install]
WantedBy = multi-user.target
It says
    * You're defining a systemd "Unit"
    * It has a description as shown
    * It should be loaded after the network target is successfully loaded
    * It's a service
    * It should be started by executing the script mentioned by the ExecStart line. Don't forget to adjust this for where your serviio.sh script is actually located!
    * And that the muli-user state wants it to be loaded.
Now, if you want Serviio to be loaded every time the machine boots, reaches the network up and multi-user states, enable it:
systemctl enable serviio.service
Whether or not it's "enabled" you can still stop it, start it, or check it's status:
# systemctl status serviio
● serviio.service - Serviio DLNA media streaming server
   Loaded: loaded (/etc/systemd/system/serviio.service; enabled; vendor preset: disabled)
   Active: active (running) since Wed 2018-08-22 20:03:50 CDT; 44min ago
 Main PID: 29556 (java)
    Tasks: 122 (limit: 4915)
   Memory: 918.4M
   CGroup: /system.slice/serviio.service
           └─29556 java -Xmx2048M -Xms1024M -XX:+UseG1GC -XX:GCTimeRatio=1 -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 -Djava.net.preferIPv4Stack=true >
Aug 22 20:03:50 clarke.localdomain systemd[1]: Started Serviio DLNA media streaming server.
Aug 22 20:03:50 clarke.localdomain serviio.sh[29556]: Serviio Media Server
# systemctl start serviio.service
# systemctl stop serviio.service
Keep in mind that starting and stopping it won't change it's enabled (or not enabled) state. You have to use
  or
systemctl disable serviio.service
for that.
This is a really basic simplistic systemd unit file, and a lot more could be done with it. Perhaps I'll update this as I discover new stuff.
Post Tue Aug 28, 2018 11:32 am
Re: HOWTO: Make Serviio auto-start under Linux (Red Hat, Fed
nice one. Maybe you copuld move it over to the wiki article / update those that are affected. thanks
