Cannot create instance of SOAP MeError after fresh install.
roginovicci
Post Tue Oct 09, 2018 10:34 am
My OS is OpenSuse Leap 15.0 with Oracle JRE version 10.0.2. After installing Serviio I have access to console to control shared data and status of the server, but all players can't get acess to the data invoking the following error in log file:
2018-10-09 13:18:28,704 ERROR [SOAPMessageParser] Cannot create instance of SOAP MessageFactory
javax.xml.soap.SOAPException: Unable to create message factory for SOAP: Unable to create SAAJ meta-factory: Provider com.sun.xml.internal.messa
ging.saaj.soap.SAAJMetaFactoryImpl not found
        at java.xml.soap/javax.xml.soap.MessageFactory.newInstance(MessageFactory.java:120)
        at org.serviio.upnp.protocol.soap.SOAPMessageParser.<clinit>(SOAPMessageParser.java:35)
        at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:70)
        at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:65)
        at org.serviio.upnp.webserver.AbstractRequestHandler.handle(AbstractRequestHandler.java:66)
        at org.apache.http.protocol.HttpService.doService(HttpService.java:423)
        at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:78)
        at org.apache.http.protocol.HttpService.handleRequest(HttpService.java:341)
        at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:204)
Should I download additional java library to resolve the problem?
Thank you in adance.
Post Tue Oct 09, 2018 12:39 pm
Re: Cannot create instance of SOAP MeError after fresh insta
That might be too new a version of Java, but Zip will have to say for sure.
Post Tue Oct 09, 2018 3:16 pm
yes. Are you using serviio.sh from the latest version? That should have a workaround.
roginovicci
Post Tue Oct 09, 2018 5:47 pm
atc98092 wrote:That might be too new a version of Java, but Zip will have to say for sure.
The previous version of java 9.xx the same problem
roginovicci
Post Tue Oct 09, 2018 6:01 pm
zip wrote:yes. Are you using serviio.sh from the latest version? That should have a workaround.
Yes I downloaded version serviio-1.9.2-linux.tar.gz and unpack it. This one is the lattes I suppose. I've checked the vriables:
$JAVA9_OPTS=--add-modules java.xml.ws,jdk.unsupported
$SERVIIO_HOME=/opt/serviio
$SERVIIO_CLASS_PATH=/opt/serviio/lib/*:/opt/serviio/config
$JAVA_HOME=/usr/lib64/jvm/java
The last string is a little bit strange. Will try to work arround here
roginovicci
Post Tue Oct 09, 2018 7:49 pm
I've found openjdk was installed (wich I belived was ubinstalled after Oracle sde instalation) and acting wierd. After total clean up from openjre/openjdk Serviio works like a charm. Thank you for support!
