Remote function does not work
pamelamadingdong
Post Wed Oct 17, 2018 8:55 pm
Hi there
After changing my provider, I had to setup my new router. I forwarded the port 23424 TCP to the local IP adress of my server and also setup my DDNS. Somehow, i can't reach the mediabrowser. Does anyone have a clue, what the problem could be? Serviio says that remote access is active.
Greets
Post Wed Oct 17, 2018 11:18 pm
Re: Remote function does not work
That's all I have set on mine. Without divulging your DDNS name, what URL are you using to connect from outside the Internet? It should be http://DDNS_Name:23424/MediaBrowser
