pro version
3031
Post Sat Oct 27, 2018 6:22 am
pro version
hi
if i buy pro version i have it for any future versions or?
thanks
3031
Post Sat Oct 27, 2018 6:24 am
Re: pro version
btw serviigo is not anymore on google play. any other good replacement for it?
Post Sun Oct 28, 2018 2:24 am
Re: pro version
When you buy Pro, it is good until the next major version number update. By major, I mean when he reaches 2.0. Right now he's on 1.10, with no near plans to jump the major version number.
Serviigo is developed by someone other than the Serviio developer. Last I heard, he removed it from the Play store because of an issue, and is currently working through the Google authorization process to get it back in the store. So it will be returning.
