Opensubtitles credentials not showing on Serviio console
muaddibii
Post Sun Oct 28, 2018 4:05 pm
I'm trying to enter my Opensubtitles credentials on the Serviio conse, but the textboxes to do it doesn't appear. I check the box to use opensubtitles but I don't see any textbox to enter the credentials.
The help button says I can do it.
Is this a know bug? Is there any other setting to activate these textboxes? If not, is there any configuration file where I can enter this information manually?
Thanks in advance for your help,
Best regards,
Marc
Post Sun Oct 28, 2018 7:47 pm
Re: Opensubtitles credentials not showing on Serviio console
It has been removed in 1.10, as Serviio now uses a different API which doesn't use the user credentials
muaddibii
Post Mon Oct 29, 2018 5:48 pm
Thanks very much for your reply.
Best regards,
Marc
