AppleTV + Serviio + Infuse
Alpha5
Post Fri Jun 29, 2018 12:23 pm
Hi
I have multiple devices at my home for which I use Serviio as DLNA server. I stream files with external SRT so I enabled burned-in subtitles for my devices that don't support SRT. I also have some older devices for which I had to enable transcoding. This all works perfectly.
But now I bought an AppleTV for my newest setup and I installed Infuse to stream my files from Serviio. I'm using the Generic DLNA profile for AppleTV to avoid transcoding but since an external SRT is found & burned-in subs is enabled this fails to playback. Regular files without external SRT play perfectly on AppleTV with Infuse.
Is there a way to have a profile for AppleTV that completely ignores all transcoding & burned-in sub settings? I need to keep the options for transcoding & burned-in subs enabled for my older devices...
Alpha5
Post Sat Jun 30, 2018 8:37 pm
Re: AppleTV + Serviio + Infuse
I found someone with the same issue but hasn't been a solution as of yet for it...
https://firecore.com/forum/topic/12520
roundup
Post Thu Nov 01, 2018 9:42 am
You can use a Samsung E/F series profile, it works very well with Serviio - Infuse - Apple TV
