Help! No audio with certain mkv files
Brendanbr12
Post Thu Sep 29, 2016 8:31 am
Old forum posts about this issue don't seem to apply anymore with a lot of C/D changing over the years.
This is the audio setup for one of the episodes of the show
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 23mn 2s
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Frame rate : 46.875 fps (1024 spf)
Compression mode : Lossy
Delay relative to video : 9ms
Stream size : 15.6 MiB (9%)
Language : English
Default : Yes
Forced : No
Please help!
momchil
Post Sat Nov 24, 2018 6:40 pm
Re: Help! No audio with certain mkv files
I have same issue.
The problem is here : "Delay relative to video"
If the audio is delayed in the mkv container, the stream don't have audio.
zip, can you find solution?
Post Thu Nov 29, 2018 8:35 am
can you post ffmpeg -i for the file?
momchil
Post Thu Nov 29, 2018 10:58 pm
Container problem... Sorry!
