Too many packets buffered FFMPEG 4 Error (v1.10.1 on Ubuntu)
GallowsHumour
Post Sat Feb 23, 2019 11:22 am
I am trying to play a video file across the web-based media browser for serviio. I am using Serviio 1.10.1 on Ubuntu 16.04 with ffmeg 4.1.1 (which I installed over a PPA). Some files play correctly but I have recently gotten an error
2019-02-23 10:49:09,895 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
Too many packets buffered for output stream 0:1.
[aac @ 0x556f0bd14640] Qavg: 884.127
[aac @ 0x556f0bd14640] 2 frames left in the queue on closing
Conversion failed!
The file isn't corrupted insofar as it plays using the Videos app in ubuntu. The file has these characteristics
Matroska video (video/x-matroska)
Video Codec: H.264
Video Framerate: 24 frames per second
Video Bitrate: 22381 kbps
Audio: E-AC-3 (ATSC A/52B)
Audio Channels: Surround S.1
Audio Sample rate: 48000Hz
Audio bitrate: 640kbps
Nothing about my Serviio setup is specialized other than I did set up a script to let it start on startup.
The following page seems to present a solution to the error but I am not sure how to add ffmpeg options to serviio.
https://stackoverflow.com/questions/49686244/ffmpeg-too-many-packets-buffered-for-output-stream-01
Post Sat Feb 23, 2019 6:19 pm
Re: Too many packets buffered FFMPEG 4 Error (v1.10.1 on Ubu
Looks like a bug in FFMpeg v4, Serviio is recommended to use with 3.x. So either wait for FFmpeg to fix it or build older FFMpeg and point Serviio to it.
GallowsHumour
Post Sat Feb 23, 2019 8:24 pm
zip wrote:Looks like a bug in FFMpeg v4, Serviio is recommended to use with 3.x. So either wait for FFmpeg to fix it or build older FFMpeg and point Serviio to it.
I actually downgraded to ffmpeg v3 via PPA. I am getting the same error
2019-02-23 20:17:02,015 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
[aac @ 0x557880538ba0] Qavg: 796.557
[aac @ 0x557880538ba0] 2 frames left in the queue on closing
Conversion failed!
The ffmpeg version is as follows
ffmpeg version 3.4.4-1~16.04.york0 Copyright (c) 2000-2018 the FFmpeg developers
  built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.10) 20160609
  configuration: --prefix=/usr --extra-version='1~16.04.york0' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
  libavutil      55. 78.100 / 55. 78.100
  libavcodec     57.107.100 / 57.107.100
  libavformat    57. 83.100 / 57. 83.100
  libavdevice    57. 10.100 / 57. 10.100
  libavfilter     6.107.100 /  6.107.100
  libavresample   3.  7.  0 /  3.  7.  0
  libswscale      4.  8.100 /  4.  8.100
  libswresample   2.  9.100 /  2.  9.100
  libpostproc    54.  7.100 / 54.  7.100
Did you perchance see the stackoverflow bug I sent in the last message? Would there be some way to add ffmpeg flags like that?
Users browsing this forum: No registered users and 77 guests
