Exception in 2.0
MarcB
Post Sat May 25, 2019 2:26 pm
Exception in 2.0
Has this been reported yet?
2019-05-25 04:18:37,721 WARN [ContentDirectory] Browse for object id A_C^INI*85^COM*2^A*762 failed with exception: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: 13
java.lang.RuntimeException: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: 13
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:276)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.findContainerItems(ContainerNode.java:202)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.retrieveContainerItems(ContainerNode.java:88)
at org.serviio.upnp.service.contentdirectory.definition.ActionNode.retrieveContainerItems(ActionNode.java:147)
at org.serviio.upnp.service.contentdirectory.ContentDirectoryEngine.browse(ContentDirectoryEngine.java:104)
at org.serviio.upnp.service.contentdirectory.ContentDirectory.Browse(ContentDirectory.java:164)
at sun.reflect.GeneratedMethodAccessor189.invoke(Unknown Source)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:214)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:75)
at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:65)
at org.serviio.upnp.webserver.AbstractRequestHandler.handle(AbstractRequestHandler.java:66)
at org.apache.http.protocol.HttpService.doService(HttpService.java:423)
at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:78)
at org.apache.http.protocol.HttpService.handleRequest(HttpService.java:341)
at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:204)
Caused by: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: 13
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:157)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:273)
... 16 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: 13
at sun.util.calendar.BaseCalendar.getCalendarDateFromFixedDate(BaseCalendar.java:453)
at java.util.GregorianCalendar.computeFields(GregorianCalendar.java:2397)
at java.util.GregorianCalendar.computeFields(GregorianCalendar.java:2312)
at java.util.Calendar.setTimeInMillis(Calendar.java:1804)
at java.util.Calendar.setTime(Calendar.java:1770)
at java.text.SimpleDateFormat.format(SimpleDateFormat.java:943)
at java.text.SimpleDateFormat.format(SimpleDateFormat.java:936)
at java.text.DateFormat.format(DateFormat.java:345)
at org.serviio.util.DateUtils.formatISO8601YYYYMMDD(DateUtils.java:47)
at org.serviio.upnp.service.contentdirectory.command.ObjectValuesBuilder.buildObjectValues(ObjectValuesBuilder.java:91)
at org.serviio.upnp.service.contentdirectory.command.AbstractEntityItemCommand.generateValuesForEntity(AbstractEntityItemCommand.java:122)
at org.serviio.upnp.service.contentdirectory.command.AbstractEntityItemCommand.retrieveList(AbstractEntityItemCommand.java:52)
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:151)
... 17 more
Post Sun May 26, 2019 3:37 pm
Re: Exception in 2.0
It might go away after the library has been fully updated.
Users browsing this forum: Baidu [Spider] and 34 guests
