Default Gateway Crashes Constantly When Streaming Video
steve757
Post Mon May 20, 2019 10:14 pm
My default gateway keeps crashing when I use Serviio.
I have no idea how to fix it!
I had this problem a long time ago, but now it's reappeared.
HELP!
Post Mon May 20, 2019 11:34 pm
Re: Default Gateway Crashes Constantly When Streaming Video
Need more information. What exactly is your default gateway (brand/model), and what exactly is happening to it when Serviio is streaming? Is this when you are using MediaBrowser from outside your network, or is it from an internal player? Is your gateway also your internal network switch, or does another switch handle your internal devices?
steve757
Post Thu Jun 06, 2019 10:01 pm
I have the all in one router/modem from Comcast/xfinity.
By the way, sorry it took so long to see your response...never got a notification!
Default Gateway . . . . . . . . . : fe80::966a:77ff:fe67:671e%15
10.0.0.1
here's the info from the router page..probably too much info!
CGM4140COM
Vendor: Technicolor
Hardware Revision: 2.2
Serial Number: 152930068502310943
Processor Speed: 1503 MHz
DRAM Total Memory: 1024 MB
DRAM Used Memory: 589 MB
DRAM Available Memory: 435 MB
Flash Total Memory: 8192 MB
Flash Used Memory: 164 MB
Flash Available Memory: 1884 MB
steve757
Post Thu Jun 06, 2019 10:04 pm
I never access my files via the net. Always via ethernet routing through my netgear wall extenders, or through wifi.
I have Comcast wifi at 400 mb speed, so that should be plenty, right?
Also, it usually happens, of course with larger files. What's the max that Serviio can stream without stuttering, or crashing my gateway?
While I'm at it, I don't find anything useful in the newest 2.0 version.
Unless I'm missing something, it's mostly for things I don't use.
Did you improve it's streaming abilities at all?
IF not, can I got back one version, and have my unlimited pro status again?
I really think you might have considered giving your longtime users a one time update for free.
steve757
Post Thu Jun 06, 2019 10:08 pm
Sorry Dan, if this is too much info.
Just wanted to make sure you had everything you needed to help me out.
This is all the info from IPCONFIG/ALL
Windows IP Configuration
Host Name . . . . . . . . . . . . : Steven-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : hsd1.or.comcast.net
Ethernet adapter Local Area Connection 2:
Connection-specific DNS Suffix . : hsd1.or.comcast.net
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : 68-1C-A2-12-AD-6E
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2601:1c0:4501:5e0b::c359(Preferred)
Lease Obtained. . . . . . . . . . : Wednesday, June 05, 2019 4:39:48 PM
Lease Expires . . . . . . . . . . : Wednesday, June 12, 2019 4:17:10 PM
IPv6 Address. . . . . . . . . . . : 2601:1c0:4501:5e0b:28a6:d466:c89f:90c1(Pr
eferred)
Temporary IPv6 Address. . . . . . : 2601:1c0:4501:5e0b:3135:1b97:5c8c:b826(Pr
eferred)
Link-local IPv6 Address . . . . . : fe80::28a6:d466:c89f:90c1%15(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.0.11(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Wednesday, June 05, 2019 4:39:50 PM
Lease Expires . . . . . . . . . . : Wednesday, June 12, 2019 4:39:50 PM
10.0.0.1
DHCP Server . . . . . . . . . . . : 10.0.0.1
DHCPv6 IAID . . . . . . . . . . . : 258481314
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-22-86-D8-CB-00-22-15-76-C1-FD
DNS Servers . . . . . . . . . . . : 2001:558:feed::1
2001:558:feed::2
75.75.75.75
75.75.76.76
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.hsd1.or.comcast.net:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Post Thu Jun 06, 2019 11:18 pm
I'm not familiar with the Technicolor routers, so have nothing to offer there. If the manual I found online is accurate (very little information actually), it only has two Ethernet ports, although they are Gigabit. I did see complaints online about it, with most users recommending using it in bridge mode and using a separate router. This removes the Technicolor from your internal network completely, and will likely provide at least 4 Ethernet ports.
I would at minimum add a Gigabit network switch to your layout. Connect one port to the Technicolor, then connect all other Ethernet cables to the switch. You can get 4-5 port switches very inexpensively, and even 8 ports aren't that much. This also partially removes the Technicolor from the majority of your network. The separate switch will only route traffic to your Technicolor when it needs to go to/from the Internet. Everything internal to your network will not touch the Technicolor except to request an IP address and for DNS services. All the traffic between your Serviio computer and your player should never touch the Technicolor. But putting the Technicolor in bridge mode and adding an additional router takes everything from your network away from it.
freaknik
Post Fri Jun 07, 2019 9:39 pm
4 port gigabit routers are a dime a dozen. My old house was set up just as atc said with switch and modem/router combo feeding it and the switch feeding another router for wifi and lan stuff.
Now since I live with less devices and people the person upstairs has one wifi network that comes from modem/router comcast pos, and it connects to my nice router downstairs over wds.
Two routers two ssid's from one ISP.
The takeaway here is to avoid using cable company router for wireless or really anything more than you have to, and everything works better.
PS most of these company routers have firmware logs all turned on and persistently log all traffic in real time. Some even with resolved ip or hostname in the log in real time. Not safe, only set up that way so ISP has something to give to law enforcement when a request of your data is made to deflect blame in fraud/catfish/stalking/swatting/whatever crime scenario.
steve757
Post Sun Jun 09, 2019 3:59 pm
i had no idea that the company supplied router modem could be the culprit!
Thanks for all the great info.
One more problem is my system. According to the tech that came out from Comcast, I'm getting slightly 1 gig from the router modem, when he hooked directly into it.
When I disable EVERYTHING on my computer, I get faster speeds.
But I can't isolate what is the speed hog.
Especially with almost all services except those I know I need turned off.
Post Sun Jun 09, 2019 6:49 pm
There are computer apps that can monitor network traffic, and many routers have logging capabilities. Perhaps that might help you track down what's eating your bandwidth.
Users browsing this forum: No registered users and 52 guests
