Can't Access Serviio Remotely
GrandM1961
Post Wed Jul 31, 2019 6:08 pm
Re: Can't Access Serviio Remotely
MarcB wrote:For the record I followed the instructions in the post: viewtopic.php?f=5&t=24520&hilit=certbot
And this still did not enable the secure connection
Ideas?
Also port forward tcp 8895 and udp 1900, see screenshot Image
Verzonden vanaf mijn iPhone met Tapatalk
Sony Bravia KDL-42W805A, iMac 27 inch late 2012, MacOS X 10.15 Beta 3
Post Wed Jul 31, 2019 9:03 pm
I don't port forward tcp 8895 or udp 1900, and I can access my MediaBrowser from the Internet. Those ports are DLNA specific, and are internal LAN use only. Port 23524 is the only open port needed for external access. However, unless you are doing some firewall magic, you have to make sure you are specifying the entire URL correctly, i.e. https://{FQDN or IP address}:23524/mediabrowser
Previous
