Shuffle playlists
depechefan
Post Sat Sep 21, 2019 9:00 am
Shuffle playlists
Just installed Serviio. Works great with my Sony STR-DN1080 receiver. I'm missing the ability to shuffle music playlists - that is: Have the music in a playlist played in random order. Any workarounds?
Thanks in advance
/M
Post Sat Sep 21, 2019 9:04 pm
Re: Shuffle playlists
In the Serviio console, on the Presentation tab, under audio there's an option to display a random title selection. Have you tried using that? I just realized you were referring to a playlist. No, I don't think there's any way to randomize a playlist.
depechefan
Post Sun Sep 22, 2019 9:54 am
Would be great to have that option. As a quick and dirty workaround I found a tool that will move lines in a text file around randomly. So that can be my solution for now. :-)
/M
