Trial version.
tempor
Post Sun Dec 22, 2019 12:33 am
Trial version.
I have installed Serviio but I wasn't able to use the PC I had it installed in and the trial license expired.
Is there a way to get a new trial license, even if it is for 1 day, to check how Serviio interacts with Serviigo?
Post Sun Dec 22, 2019 3:17 am
Re: Trial version.
tempor wrote:Hi,
If you do a fresh, clean install you will get a new 15 day trial period. So uninstall Serviio, reboot and install it clean.
tempor
Post Sun Dec 22, 2019 9:07 am
Re: Trial version.
Ok, thanks, I am on linux so I hope it applies there too.
