Windows firewall
Haki
Post Thu Jan 16, 2020 4:55 pm
Windows firewall
Windows firewall exception http://prntscr.com/qonnaq
TV doesnt detect servio, i disable windows firewall then its ok, its detecting it...
Win 10 64bit, no av, win defender disabled in every way possible.
Post Thu Jan 16, 2020 5:56 pm
Re: Windows firewall
The screenshot you posted appears to be in support of the Serviio console, which uses port 23423/23523. Here's a quote from the Serviio Wiki page: "Make sure you open TCP 8895 and UDP 1900 ports in firewall." On a Windows PC the Serviio installer is supposed to configure it automatically, but I've seen Windows updates reset the firewall without telling.
Users browsing this forum: Baidu [Spider] and 33 guests
