Mediabrowser left/right arrow keys : Time indexing
kittmaster
Post Wed Mar 18, 2020 12:57 pm
While using mediabrowser, the timeline bar works for good course seeking, however, usually when you use the left and right arrows on most video players, the video will index by 5, 10, 15 seconds for scrubbing.
On mediabrowser, it is jumping like 10 minutes for each press.
I've tried modifiers like shift right, control right, alt right.......besides increasing play speed, it doesn't do what I'd like.
Does anyone know all the keyboard hot keys for this player? Is there a way to index via keyboard by seconds vs 10 minutes? Is there any frame by frame seeking?
Thanks,
Chris
kittmaster
Post Wed Mar 25, 2020 12:40 pm
Re: Mediabrowser left/right arrow keys : Time indexing
bumping......
Zip???
Anyone?
Post Wed Mar 25, 2020 8:07 pm
No, I think it's built in feature of the player and perhaps it uses percentage of duration.
kittmaster
Post Sun Apr 05, 2020 2:35 pm
Zip, I understand that aspect, it is clear when you use the bar.
My question is, are there keyboard hotkeys that can index mediabrowser in smaller increments, like frame by frame, or 1 sec vs. the current implemention.
Did you write the code for the player? I would assume you know its capability?
thanks,
Chris
Post Mon Apr 13, 2020 5:23 pm
Hey, no I didn't write the player.
Looking at the docs, it might be possible, so please create a ticket and I'll have a look for a future release.
