"Surging" in video playback...
Quad Core Ryzen, 8 Gb RAM.
What should I look for, or has Windoze just moved up compatibility requirements forcing a hardware upgrade?
Any suggestions welcome.
dlzc wrote:Seems like this started to be consistent with any movie within the last couple of weeks. Nothing unusual is showing up in the Serviio logs. Seems to be "less" or "nonexistent" with Blue-Ray grade files, than with DVD grade files. The Serviio server is dedicated to this, Windows updates have been performed, and nothing much is showing up in Task Manager. "Surge" is about 3/4 of a second to repeat, sound is unaffected. Overall network traffic is light, since only major user at this time is the TV setup.
atc98092 wrote:I'm not following what you mean by surging. Are you talking about buffering, with the playback pausing then continuing? Or does the video "freeze" with the audio continuing?
atc98092 wrote:Yeah, it might be something with the TV firmware update.
Users browsing this forum: Baidu [Spider] and 23 guests
