Samsung qe55q90r (No Resume play?)
Now I have to try and find the place which is annoying
Does anyone know if it’s possible to fix?
atc98092 wrote:Resume play (as well as FF and rewind) depend on the file either not being transcoded, or transcoded into the HLS format. Also, some players are simply not supporting such functionality, even with non-transcoded files.
So, did Samsung change the player functionality, or is the wrong profile perhaps assigned to the TV in the Serviio profile? I can't say for sure, and I'm unfamiliar with that particular TV so I can't suggest what profile it should use. The latest Samsung profile (NU Series) might be a good starting point to test. Depending on your media, you might even get by with the generic profile, which transcodes nothing. One profile that does transcode into HLS format is the Roku 4K TV profile.
atc98092 wrote:On the Serviio console, on the Status tab, you see your network devices in a list. As you noted, your Samsung is showing green. Look further to the right, and there's a column labeled Profile. That shows the profile that Serviio assigned to your TV. Since there's no profile that matches your TV, Serviio does a best guess. But usually it will just assign the generic profile. As I mentioned, that profile does no transcoding at all. If nothing will play, then none of your media is compatible with your TV and requires transcoding. But by doesn't work I assume you are referring to the trick play functions.
So, what profile is actually assigned to your TV? When you play something on the TV, refresh the Status tab. There will be a Now Playing icon next to the green indicator. If that icon is green, there nothing is being transcoded (audio or video), so if trick play isn't working then it's the TV and there's nothing Serviio can do about it.
If the playing icon is orange, then the file is being transcoded. If that's the case, then click Edit at the right edge of the entry for your TV and choose a different profile. But before you do that, let us know what profile is currently selected.
atc98092 wrote:OK, if it's the generic profile, and the TV won't resume, that means Samsung removed that functionality. There's nothing that can be done to change that from the Serviio side. Sorry, you're stuck with it.
If all your media plays with the generic profile, there's no reason to try another. Profiles allow playback of non-compatible files. If they all play, they're all compatible.
atc98092 wrote:Yes, Plex will resume. This isn't the first time I've seen a player lose functionality. My older Sony BD players would bitstream DTS Master Audio and Dolby TrueHD, but the last one I bought lost its DTS-MA support. No problem with standard DTS, but not the lossless audio. One of many reasons I now use an Nvidia Shield on both of my 4K TVs with an AVR attached. Full lossless audio, including Atmos/DTS:X from my UHD rips. And since it has a Gigabit port, it doesn't choke on the UHD rips, either.
atc98092 wrote:Another user with a Samsung QLED set (Q80T) says that resume is working on his set. He is using the Samsung NU series profile. It can't hurt anything to try it. I can't for the life of me think of any reason the profile would make it work, but you can change from the generic profile as I described above and give it a shot.
atc98092 wrote: Samsung NU7100 4K TV, Samsung JU7100 4K TV, Sony BDP-S3500, Sharp 4K Roku TV, Insignia Roku TV, Roku Ultra, Premiere and Stick, Nvidia Shield, Yamaha RX-V583 AVR.
Primary server: Intel i5-6400, 8 gig ram, Windows 10 Pro, 18 TB hard drive space | Test server Windows 10 Pro, AMD Phenom II X4 965, 8 gig ram.
Users browsing this forum: Baidu [Spider] and 24 guests
