Correct location of -Xmx...m parameter
Paul C
Post Mon Aug 31, 2020 3:36 pm
I have noted (under v2) that I have the - Xmx...m parameter in both the files:-
../Serviio/config/user.vmoptions
--/Serviio/bin/ServiioService.exe.vmoptions
Is this correct or if not which one should it be in ?
(they had different values).
Post Mon Aug 31, 2020 3:48 pm
Re: Correct location of -Xmx...m parameter
I believe the User options file is something new for 2.1. I would expect it to override the default file, so that is where I would enter the parameter you desire to be in effect.
Paul C
Post Tue Sep 08, 2020 12:32 pm
atc98092 wrote: I would expect it to override the default file
i think it adds to the default file.
Not sure if the Xmx...m parameter exists in the default file on Serviio issue.
I will examine the situation on next release 2.2 whenever.
In the meantime probably does not matter which place it is but having it in two places with different values was probably not a good idea.
