remote tab
telex
Post Mon Nov 17, 2014 5:47 pm
remote tab
on the serviio console and can not edite the remote tab, its grey all. I can not change the password??
Post Tue Nov 18, 2014 12:39 pm
Re: remote tab
It's because the password is only used for MediaBrowser, which is available in the Pro edition.
dawid79
Post Sun Mar 28, 2021 2:43 pm
Re: remote tab
I have just bought pro version, and I still cannot set up password in the Remote tab. There is no such option.
my version is Serviio Pro 2.1
never mind, found it.
You set up user (case sensitive) and password in the Users tab, and then access mediabrowser through http://localhost:23424/mediabrowser or http://<pc5dczc_pc_ip_address>:23424/mediabrowser
Post Sun Mar 28, 2021 7:39 pm
Re: remote tab
Correct, starting with Serviio 2.0 user accounts now replace the remote access control function. Just a heads up for anyone that comes across this old thread.
Users browsing this forum: No registered users and 83 guests
