Serviio Server Need Help
SavoGamer
Post Tue Apr 13, 2021 11:30 am
I have a system that I have tried 3 versions of Serviio 1.7 1.91 and 2.0. I have used serviio on my main computer for several years with no problem. I backed up my media on a 8 bay Raid 0 spanning and then moved it over to another computer. Serviio will not start automatically. And if I start it manually, it will shut off after a period of time. Order of testing was 1.91 then 2.0, then 1.7. They were removed each time with a third party Revo Uninstaller to try to get all lines of code that may have been written each time. The server is off right now, I could go over and start it manually, but it will shut off again at some time. When it is on, it is seen on the network. Connection to the hard drive tower is via a esata cable and a silicon image 3120 esata card with port multiplier. HD case is a Mediasonic 8 bay esata/usb 3.0 device. comments or suggestions please. text to speech online
Post Tue Apr 13, 2021 1:40 pm
Re: Serviio Server Need Help
What operating system is your Serviio computer using? It might be helpful to attach your Serviio log here so we can see if anything abnormal is entered.
