An unexpected error occurred (500). Check the log.
pingoes
Post Fri Dec 03, 2021 2:29 am
Ive been using Serviio V.2.1 and i recently upgraded to 2.2.
Since then, ive been experiencing some issues so i decided to delete my profile on my app data and reconfigure everything on my Windows 10 PC.
Since then, cannot add any of my hard drive folders in order to synchronize the movies.
When i go to search and add the data, i get the error message An unexpected error occurred (500). Check the log. (this happen when I try to search for my drives on my Serviio console).
I went to see the logs and i got this error:
2021-12-02 21:22:13,066 WARN  [ServiioStatusService] UncheckedIOException occurred. Returning error code 500 to the REST layer. Message: java.nio.file.FileSystemException: U:\: Data error (cyclic redundancy check).
java.io.UncheckedIOException: java.nio.file.FileSystemException: U:\: Data error (cyclic redundancy check).
   at java.nio.file.Files$2.hasNext(Files.java:3462)
   at java.util.Iterator.forEachRemaining(Iterator.java:115)
   at java.util.Spliterators$IteratorSpliterator.forEachRemaining(Spliterators.java:1801)
   at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:482)
   at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:472)
   at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708)
   at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
   at java.util.stream.LongPipeline.reduce(LongPipeline.java:461)
   at java.util.stream.LongPipeline.sum(LongPipeline.java:419)
   at java.util.stream.ReferencePipeline.count(ReferencePipeline.java:593)
   at org.serviio.ui.resources.server.BrowseFileSystemServerResource.hasFolderChildren(BrowseFileSystemServerResource.java:80)
   at org.serviio.ui.resources.server.BrowseFileSystemServerResource.lambda$0(BrowseFileSystemServerResource.java:61)
   at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193)
   at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:175)
   at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1382)
   at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:566)
   at org.serviio.ui.resources.server.BrowseFileSystemServerResource.loadRoots(BrowseFileSystemServerResource.java:61)
   at org.serviio.ui.resources.server.BrowseFileSystemServerResource.getFoldersForDirectory(BrowseFileSystemServerResource.java:55)
   at org.serviio.ui.resources.server.BrowseFileSystemServerResource.listFolders(BrowseFileSystemServerResource.java:34)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
   at org.restlet.resource.ServerResource.doHandle(ServerResource.java:511)
   at org.restlet.resource.ServerResource.get(ServerResource.java:723)
   at org.restlet.resource.ServerResource.doHandle(ServerResource.java:603)
   at org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:662)
   at org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:348)
   at org.serviio.restlet.AbstractServerResource.doConditionalHandle(AbstractServerResource.java:49)
   at org.restlet.resource.ServerResource.handle(ServerResource.java:1020)
   at org.restlet.resource.Finder.handle(Finder.java:236)
   at org.restlet.routing.Filter.doHandle(Filter.java:150)
   at org.restlet.routing.Filter.handle(Filter.java:197)
   at org.restlet.routing.Router.doHandle(Router.java:422)
   at org.restlet.routing.Router.handle(Router.java:641)
   at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:140)
   at org.restlet.engine.CompositeHelper.handle(CompositeHelper.java:202)
   at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:77)
   at org.restlet.Application.handle(Application.java:385)
   at org.restlet.Component.handle(Component.java:408)
   at org.restlet.Server.handle(Server.java:507)
   at org.restlet.engine.connector.ServerHelper.handle(ServerHelper.java:63)
   at org.restlet.engine.adapter.HttpServerHelper.handle(HttpServerHelper.java:143)
   at org.restlet.ext.simple.internal.SimpleContainer.handle(SimpleContainer.java:74)
   at org.simpleframework.http.core.Dispatcher.dispatch(Dispatcher.java:121)
   at org.simpleframework.http.core.Dispatcher.run(Dispatcher.java:103)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
   at java.lang.Thread.run(Thread.java:748)
Caused by: java.nio.file.FileSystemException: U:\: Data error (cyclic redundancy check).
   at sun.nio.fs.WindowsException.translateToIOException(WindowsException.java:86)
   at sun.nio.fs.WindowsException.asIOException(WindowsException.java:106)
   at sun.nio.fs.WindowsDirectoryStream$WindowsDirectoryIterator.readNextEntry(WindowsDirectoryStream.java:178)
   at sun.nio.fs.WindowsDirectoryStream$WindowsDirectoryIterator.hasNext(WindowsDirectoryStream.java:209)
   at java.nio.file.Files$2.hasNext(Files.java:3460)
   ... 72 more
Any orientation or suggestion on how to fix this issue ?
Thanks in advance.
Post Fri Dec 03, 2021 3:35 pm
Re: An unexpected error occurred (500). Check the log.
I noticed that the log is indicating a U: drive. Is this a local drive, or something on the network? Serviio runs on as a Local System user, and has limited permissions for non-local drives. The first thing I'd try is changing the user account that Serviio uses to the same user account you use to log into the computer. In Windows, you change that using the Services applet. Find Serviio and open the properties. There's a login tab that lets you change the user. Make sure you have the user name and password correct, as it doesn't validate the info when you enter it. Then restart the Serviio service and see if your problem is resolved.
