Cannot link to Alexa
Rick66
Post Tue Sep 07, 2021 1:09 pm
Hi
I have been using Serviio (and MyMedia, a similar program) for some time but just upgraded my PC. I re-downloaded Serviio and noticed that the Pro version can be used with Alexa. Now I have a 14 day trial of Pro but cannot work out how to link alexa so I can try it out.
I ran the serviio console and have my ID. I have loaded Alexa and enabled the skill. This is the part I have problems with [3. Authenticate using your Serviio Id (from the Console home screen), User name and User Password (from the Console Remote tab) and click Sign In.] I dont know how to get a username and password from the Remote tab. My remote tab is about connectivity.
I set up a user on the user tab and tried to use the username and password and my Serviio ID to link my account in the Alexa app but it says "The provided credentials are not valid. Try again".
What am I not doing right?
Post Wed Sep 08, 2021 12:01 am
Re: Cannot link to Alexa
I am assuming you read the information here: https://www.serviio.org/alexa
It sounds like that info was written for Serviio before version 2.0. User accounts are a new feature starting with 2.0 , and are on a separate Users tab on the console. But there are two steps to creating and using a User account. First of course is to create the user name and password. But then you have to go into your Library Shared Folders and give that user explicit permission to use that library. If you have multiple shared folders ( I have seven), you have to grant that permission to each folder you want that user to be able to access. This step is often overlooked and can cause access problems. :D
At the very top of that page is a link to setting up remote access. Make sure you've followed all of those steps first, as that is required (I believe) for Alexa to work.
JamesCurran
Post Wed Dec 29, 2021 9:33 am
I'm experiencing the same problem.
- I am currently using the free evaluation version of Serviio Pro (for a few more days) (I was hoping to get this working before I had to pay for it)
- I can access the media browser remotely (http://james-curran.com:23424/mediabrowser/#/browse) using the username & password
- Whenever I attempt to link the account to the Alexa skill, it responds "The provided credentials are not valid. Try Again" (I have double- and triple-checked them; they are correct).
- Viewing the HTTP traffic for the logon, (https://y2il4cp25a.execute-api.us-east- ... prod/login), it gets a http 401 status, with the message "Authentication error: ServiioId nG8TiytDFT not found".
- So, it seems that the Alexa service doesn't know about my server. How do I tell it about it?
teacherguy
Post Mon Jan 03, 2022 11:42 pm
Same for me, can access the media browser from any device in my house, but not getting anywhere with the Alexa skill.
teacherguy
Post Tue Jan 04, 2022 12:08 am
OK, after trying to link the skill many times, it magically took (perhaps my IP had to work its way through to serviio, who knows).
This is also helpful:
https://serviio.org/alexa
Users browsing this forum: Baidu [Spider], Google [Bot] and 73 guests
