Reverse Proxy Serviio via sub path
HorsePDF
Post Tue Sep 28, 2021 12:26 pm
Hey,
I have a domain like apps.xyz.com that hosts a bunch of things.
Each app is located in a path underneath the hostname, and I'm using nginx to reverse proxy to the correct location.
The only app I can't get working is Serviio right now - I can get the assets such as HTML, CSS and JS to load, but the application seems to be making API requests directly to /rest/... where the app is now hosted at /serviio/console/...
Some of the other applications I set up didn't need any special configuration, but some needed me to set the web path in configuration which then allowed this to work simply. But I can't find any such configuration option for Serviio.
Is this possible? Any advice? I've had a search on the forum but it's mostly using subdomains instead of path to separate apps which is not what I want to do ideally...
Nginx config
location /serviio/ {
        proxy_set_header Host $host;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_pass http://172.16.0.123:23423/;
Resulting failure example
GET 404 - https://apps.xyz.com/rest/library-status
Need the application to be making the request to
https://apps.xyz.com/serviio/rest/library-status
Thanks in advance
seanhodg
Post Fri Feb 18, 2022 8:28 pm
Re: Reverse Proxy Serviio via sub path
do you use any proxy for your work?
Users browsing this forum: Google [Bot] and 82 guests
