Help reduce CPU and LAN activity
BillGrimm
Post Tue Apr 26, 2022 1:27 am
I am using Serviio 2.2.1 on low-end new laptop. In general, it all works really well. However, there is a tendency for Serviio to eat up more and more CPU power and LAN bandwidth over time.
For example, currently I only have the Sony TV (which isn't on) and the laptop server itself listed as connected devices. When the server is started, Task Manager typically shows a send throughput of around 232kbps and a receive throughput of about 40kbps. I'm pretty sure this is all local traffic. But sometimes, after a while, the send throughput will crawl up to about 1.4Mbps with the receive throughput increasing to 240kbps or so. Just today, it was even as high as 3.2Mbps/720kbps!
What is going on, and can I somehow tell Serviio to stay in the 232kbps/40kbps range of activity all the time? Obviously, when I am streaming a film to the TV it goes up hugely but that is expected. What I want is it for then to return to the low activity state once streaming is complete because when it is really gobbling the bandwidth it is also taxing the CPU pretty high as well.
Thanks in advance for your help!
BillGrimm
Post Tue Apr 26, 2022 3:47 pm
Re: Help reduce CPU and LAN activity
Here's some debug log:
2022-04-26T08:29:41,857 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:41,864 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:41,890 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (Intel(R) Wi-Fi 6 AX201 160MHz) and address 192.168.1.104, timeout = 0
2022-04-26T08:29:41,890 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a
2022-04-26T08:29:41,957 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47426: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:41,958 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:41,958 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:41,958 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:41,958 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:41,959 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:41,959 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:41,959 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:42,060 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47428: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:42,061 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,061 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,061 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:42,061 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:42,062 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:42,165 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47430: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:42,166 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,166 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,166 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:42,166 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:42,167 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:42,267 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47432: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:42,268 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,268 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,268 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:42,268 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:42,269 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:42,367 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47434: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:42,368 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,368 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,368 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:42,368 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:42,369 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,369 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,369 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:42,470 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47436: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:42,471 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,471 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,471 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:42,472 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,472 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:42,472 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,472 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:42,676 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47438: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:40 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]]
2022-04-26T08:29:42,676 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,676 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,676 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:40 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";])
2022-04-26T08:29:42,676 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:40 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]
2022-04-26T08:29:42,677 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,677 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:42,679 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47440: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:42,679 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,680 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,680 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:42,680 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,680 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:40 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:42,681 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:42,688 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47442: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:40 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]]
2022-04-26T08:29:42,688 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,688 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,688 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2022-04-26T08:29:42,689 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2022-04-26T08:29:42,697 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47444: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:40 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]]
2022-04-26T08:29:42,697 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,698 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,698 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2022-04-26T08:29:42,698 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2022-04-26T08:29:42,708 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47446: GET /serviceDescription/X_MS_MediaReceiverRegistrar HTTP/1.1, headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:40 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]]
2022-04-26T08:29:42,710 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,710 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,710 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2022-04-26T08:29:42,710 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2022-04-26T08:29:42,778 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47448: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:42,778 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,779 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,779 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47450: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:41 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]]
2022-04-26T08:29:42,779 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,779 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:42,779 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:42,780 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:41 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";])
2022-04-26T08:29:42,780 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,780 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,780 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:41 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]
2022-04-26T08:29:42,780 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:42,781 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:42,788 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47452: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:41 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]]
2022-04-26T08:29:42,788 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,788 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,788 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2022-04-26T08:29:42,789 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2022-04-26T08:29:42,796 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47454: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:41 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]]
2022-04-26T08:29:42,796 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,796 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,796 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2022-04-26T08:29:42,797 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2022-04-26T08:29:42,809 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47456: GET /serviceDescription/X_MS_MediaReceiverRegistrar HTTP/1.1, headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:41 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]]
2022-04-26T08:29:42,809 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,810 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,810 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2022-04-26T08:29:42,810 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2022-04-26T08:29:42,881 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47458: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:42,881 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,881 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47460: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:41 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]]
2022-04-26T08:29:42,881 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,881 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:42,881 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:41 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";])
2022-04-26T08:29:42,881 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:42,882 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,882 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,882 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:41 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]
2022-04-26T08:29:42,882 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:42,891 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47462: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:41 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]]
2022-04-26T08:29:42,891 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,892 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,892 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2022-04-26T08:29:42,892 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2022-04-26T08:29:42,900 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47464: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:41 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]]
2022-04-26T08:29:42,900 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,901 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,901 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2022-04-26T08:29:42,901 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2022-04-26T08:29:42,910 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47466: GET /serviceDescription/X_MS_MediaReceiverRegistrar HTTP/1.1, headers = [Host: 192.168.1.104:8895,Date: Tue, 26 Apr 2022 14:29:41 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";]]
2022-04-26T08:29:42,910 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,910 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,910 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2022-04-26T08:29:42,910 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2022-04-26T08:29:42,980 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47468: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:42,980 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,980 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,980 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:42,980 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:42,981 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:42,981 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:42,981 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:43,084 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47470: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:43,084 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,085 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,085 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:43,085 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,085 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:43,086 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,086 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,086 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:43,191 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47472: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:43,191 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,191 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,191 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:43,191 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:43,192 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,192 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,192 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:43,290 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47474: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:43,290 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,290 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,290 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:43,290 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:43,291 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,291 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,291 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:43,392 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47476: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:43,392 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,393 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,393 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:43,393 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,393 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:43,393 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:43,449 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2022-04-26T08:29:43,496 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47478: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:43,496 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,496 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,496 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:43,497 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,497 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:43,497 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,497 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:43,598 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47480: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:43,598 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,598 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,598 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:43,599 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:43,599 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,599 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,599 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:43,699 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47482: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:43,700 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,700 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,700 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
2022-04-26T08:29:43,700 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:41 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]
2022-04-26T08:29:43,701 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,701 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,701 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Roku 4K TV'
2022-04-26T08:29:43,802 DEBUG [ServiioHttpService] Incoming request from /192.168.1.101:47484: GET /deviceDescription/fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a HTTP/1.1, headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:42 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19]]
2022-04-26T08:29:43,803 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.101
2022-04-26T08:29:43,803 DEBUG [RendererService] Rendered 23456789-1234-1010-8000-94db56ac9846 doesn't have a User assigned to it, using Default
2022-04-26T08:29:43,803 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device fc0b1b2d-dce6-34b8-a6e0-91a45af2e44a from 192.168.1.101 (headers = [HOST: 192.168.1.104:8895,DATE: Tue, 26 Apr 2022 14:29:42 GMT,CONNECTION: close,USER-AGENT: Linux/4.9.125, UPnP/1.0, Portable SDK for UPnP devices/1.6.19])
It goes on and on like that.
Also, the pattern of activity has changed, now (this is all Serviio activity):
BillGrimm
Post Wed Apr 27, 2022 1:56 pm
Today, the activity for Serviio has continued to increase again. Now it has send throughput bouncing between 1.2Mbps-1.7Mbps and receive throughput between 104Kbps-336Kbps. Also, the CPU load is 42%! What is it doing that requires this amount of activity? Can anyone help?
Post Thu Apr 28, 2022 12:00 am
The only thing I can think of is Serviio refreshing the metadata in the database. But that's normally only done on initial Serviio installation, and then as new media is added. I've heard of users with exceptionally large libraries taking more than a day to complete the update, but for most users it should be done in a matter of hours.
40% CPU isn't high enough for video transcoding, and it's too high for just audio transcoding. Have you looked at your Status page in the Serviio console to see if there's any activity shown? Any devices that are streaming some media? Someone sneaking on your WiFi and watching some of your content? The network data could be a low bitrate video, or perhaps an audio stream. If any device is actually streaming from Serviio, the Status page will show an indicator like this:
That green indicator will be orange if the media is being transcoded.
BillGrimm
Post Thu Apr 28, 2022 2:21 pm
I have Serviio set up to only serve the video files as is -- no transcoding at all. I also have thumbnails produced, but no metadata retrieval. It should be pretty dormant when there are no rendering devices connected. As I said above, only two devices are connected -- my Sony TV and the laptop server itself. In the detailed log, it looks like Serviio is chatting it up pretty heavy with the TV (192.168.1.101), even though the TV (a Bravia 4K model) is in sleep mode. This chatting gets more and more intense, resulting in the rising throughput to the local network. My question: But why? And how can I reduce it?
Now, most of that chatter goes away when I simply do a hard shutdown of the Sony TV. Serviio is still sending out its announcements or whatever, but that is only 80Kbps activity on the LAN. I'm looking for settings for Sertviio or for my Sony TV that would keep this chatter between the two of them to a minimum. Any ideas?
Post Thu Apr 28, 2022 3:17 pm
Hopefully Zip will see this post and look that log over. It's over my head, so he's the only one that can really answer that question. Glad to hear it's not actually chatting out to the Internet with all that traffic. I don't have a Sony TV, so I can't look if I see the same sort of behavior.
BillGrimm
Post Thu Apr 28, 2022 4:28 pm
Thanks for your help! Is there a way to bring it to Zip's attention, if he is the only one with the knowledge to address the issue?
Post Thu Apr 28, 2022 8:18 pm
Zip is the developer, so he's the one true "know it all" about Serviio. You can send him a private message using the Messages button at the top of the page if he doesn't respond here. I believe real life has been keeping him occupied some some Serviio work might be on the back burner for now.
Post Fri Apr 29, 2022 4:29 pm
Yeah, looks like 192.168.1.101 is constantly requesting the descriptions of Serviio services. Not sure why - but not much Serviio can do about it - i just responds.
Make sure you have a recent firmware on that device I guess.
BillGrimm
Post Fri Apr 29, 2022 6:55 pm
All right. I just wanted to see if it was the TV causing the problem or my Serviio setup. I'll see what I can do about the TV. The odd thing is, it just suddenly started doing this kind of thing -- I'd never had trouble with it until a few weeks ago when this new behavior started.
Post Sat Apr 30, 2022 3:20 pm
There hasn’t been a recent update to Serviio, so the likely culprit is a firmware update on the TV itself. Certainly wouldn’t be the first time that a TV manufacturer damaged something with DLNA with a firmware update, and sadly won’t be the last.
BillGrimm
Post Mon May 02, 2022 2:24 am
Well, the TV tells me its software is all up to date. I'm wondering if it is VLC doing it, since that is the media player I use on the TV. But I checked, and that is also the latest version. I have Serviio on a frequent advertisement rate, but I've had it like that for a while now with no problems. The trouble I was having there was when I was using either the Sony media player or VLC, there would be considerable lag when I turned the TV on before it could find the DLNA server. It was annoying, so I set it to advertise every 10 seconds. But like I say, I did that some months ago -- long before my present issues appeared.
Does anyone have any other thoughts on this or similar experience?
Users browsing this forum: No registered users and 53 guests
