[SOLVED]1.9 Not seeing movies that 1.8 did
railfrog
Post Sun Jul 30, 2017 2:54 pm
Just upgraded to 1.9
There are now 11 movies which I could see on my device in the previous version which have now "disappeared".
I think it might have something to do with the "user rating" button on the "video presentation" tab.
I disabled it in the new version and now I can't see certain movies.
Post Tue Aug 01, 2017 1:02 pm
Re: 1.9 Not seeing movies that 1.8 did
railfrog wrote:I think it might have something to do with the "user rating" button on the "video presentation" tab.
Nah, that only stops the category from being displayed. Set it back and the category should be re-displayed.
Suspect the profile has changed (had you customised it previously) and some file are not being transcoded which need to be. Look at the 11 files using MediaInfo - is there a common video format or audio format across the files?
railfrog
Post Tue Aug 01, 2017 6:04 pm
Hi and thanks for the reply.
Cannot see a common link for the files.
Can't remember if I did customise one of the profiles.
Would it have backed up anywhere when I upgraded?
DIXXX
Post Tue Aug 01, 2017 9:06 pm
I had the same problem, after long tries - solution:
1. Delete all folders from the chosen for video.
2. RENAME folders on computer (keep the videos).
3. Set NEW folders in Serviio.
I do not know why and how, - it worked for me!
railfrog
Post Tue Aug 01, 2017 10:39 pm
Nice one DIXXX
All my movies are just files, no folders, so a rename of each and it worked.
Is this a bug on the new version?
Post Tue Aug 01, 2017 10:48 pm
Did either of you try doing a Force Refresh to see it the worked?
railfrog
Post Tue Aug 01, 2017 11:06 pm
DenyAll wrote:Did either of you try doing a Force Refresh to see it the worked?
Many a time
cara
Post Thu Feb 02, 2023 6:57 am
DIXXX wrote:I had the same problem, after long tries - solution:
1. Delete all folders from the chosen for video. among us
I followed you and it worked for me, thanks.
Users browsing this forum: Google [Bot] and 77 guests
