Cannot connect to the server, it doesn't seem to be running.
mgrm
Post Thu Jan 27, 2022 12:15 pm
Re: Cannot connect to the server, it doesn't seem to be runn
Hi there, pls, after update to macOS Monterey 12.2 from 12.1 serviio stop running, any ideas for solution?
I tried complete removal and reinstalling 3 times.
Log as attachment
Thx in advance
(5.73 KiB) Downloaded 581 times
Post Thu Jan 27, 2022 3:02 pm
Well, according to the log there's an issue with the creation of the database. Make sure you completely remove your current Serviio install, then install it fresh again. Since I have zero experience with a Mac, I can't tell you how to ensure the existing Serviio is completely removed. Based on your log, it appears to have a different file structure than a Windows install.
Post Tue Feb 21, 2023 2:37 pm
borsambeg wrote:Have you checked to make sure that your server is still running and that it's properly configured? The update may have changed some settings or caused a conflict with another program.
His log shows Serviio isn't running. There's a config issue that needs to be cleared, and the only way to do that is to completely remove Serviio and install and configure it from the beginning.
Previous
Users browsing this forum: Google [Bot] and 33 guests
