Preferred language of subtitles
OiKeeep
Post Mon Aug 21, 2023 12:53 am
Hello, I'm new to the forum, I apologize if I'm posting in the wrong place and for the translation, I don't speak English.
I'm having a problem with the subtitle, I put the favorite language in the subtitle of the player that I use and also in the server, but when I put it to play, the subtitle does not change, it remains in English. On the computer using media player classic I don't have this subtitle problem. How can I do to resolve?
https://imgur.com/a/e3q650B
Post Mon Aug 21, 2023 1:48 am
Re: Preferred language of subtitles
Subtitle problems are often something to do with the player, not the source (such as Serviio). What are you using for the player? If it's a Smart TV interface, just be aware that many TVs have less than stellar DLNA player support. Some players, such as Roku devices, can only display captions if the captions are text based, such as broadcast TV or external captions files (most often in an SRT container). from the image you linked, it appears your captions are from Subrip, so those should be text based captions.
If you have any other player you could possibly try with these files, that would help and see if the problem is the player you're first trying.
Your translation is fine! :D
OiKeeep
Post Mon Aug 21, 2023 4:03 am
atc98092 wrote:Subtitle problems are often something to do with the player, not the source (such as Serviio). What are you using for the player? If it's a Smart TV interface, just be aware that many TVs have less than stellar DLNA player support. Some players, such as Roku devices, can only display captions if the captions are text based, such as broadcast TV or external captions files (most often in an SRT container). from the image you linked, it appears your captions are from Subrip, so those should be text based captions.
Thanks for answering. I managed to solve it, my Brazilian Portuguese language is probably having a problem with the VLC player to detect the corresponding subtitle, I just put the Portuguese language from Portugal and it detected Brazilian Portuguese in the subtitle, it doesn't make much sense, but it solved it here. Thanks
Users browsing this forum: Baidu [Spider], Google [Bot] and 73 guests
